Price: $49.99
(as of – Details)
【EMERGENCY USES】Designed for every single emergency use and outdoor adventures. OMEW battery powered radio can double as a portable charger to keep your devices powered for summon help. Upgraded overvoltage protection design will protect itself and the powered devices for safer use.
【GREEN POWER SUPPLY】OMEW portable survival radios recharge from solar panel and hand crank. TWO alternative ways to recharge: through the wall outlet or the car outlet. 4 power indicator lights show the remaining battery clearly for you to keep track of the power and multiple charging options ensure the emergency radio never run out of battery when you need it most. This lightweight wind up radio is easy to carry and operate wherever you go
【S.0.S. & BRIGHT LED FLASHLIGHT & READING LIGHT】 The S.O.S. feature is extremely effective in getting attention and letting others in your vicinity know that something is wrong. Extremely bright LED flashlight emits 130 lumens with 3 modes. Press the LED light switch to change the mode. Makes an ease and warm environment while chat with your families, and will bring you countless beautiful nights without worrying about the power outage.
【QUALITY ASSURANCE AND COMPLETE CERTIFICATION】Given the increasingly uncertain nature of the world, it has occurred to us that maybe we should give some thought to what we would (will) do if we ever find ourselves in a Time of Dire. -Be predictable in the face of unpredictable- OMEW emergency crank radio will be a good helper for emergency. Package includes: 1* emergency radio, 1* charging cable, and 1*user manual.
