Price: $35.99
(as of Mar 15, 2025 03:30:29 UTC – Details)
About PPLEE
· PPLEE is committed to exploring every detail of weather radio, constantly thinking and scrutinizing every optimization and innovation point in the product development process.
· PPLEE is committed to providing high-quality and reasonable-priced products to every PPLEE customer.
· Every PPLEE customer experiences every segment of life more exquisitely and delicately, Living a truly comfortable life is exactly PPLEE’s Mission.
How did we get our start?
The weather is not always sunny, and with bad weather comes panic because you’re not ready.
This weather radio gives you early warning of the weather with NOAA real-time weather forecast and has so many functions for your to prepare: 5 sustainable power sources, AM/FM/SW radio, SOS singal and loud alarm, flashlight and reading lamp, works as a power bank to boost a dead phone in emergency.
Why do we love what we do?
We image, we design, we use, we collect suggestions, we update, then we have this portable weather radio come out.
PPLEE Emergency Weather Radio
Solar Crank NOAA Weather Radio
PPLEE 5 ways powered 𝗲𝗺𝗲𝗿𝗴𝗲𝗻𝗰𝘆 𝘄𝗲𝗮𝘁𝗵𝗲𝗿 𝗮𝗹𝗲𝗿𝘁 𝗿𝗮𝗱𝗶𝗼 will help you to earn a critical time for survival!
Best home / outdoor survival gear for emergency power outages
Auto Alert Weather Radio
Get fully prepared even at night while you are sleeping!
【5000 Large Capacity Built-in Battery】Compared with other emergency radio on the market, this 𝗽𝗼𝗿𝘁𝗮𝗯𝗹𝗲 𝘄𝗲𝗮𝘁𝗵𝗲𝗿 𝗿𝗮𝗱𝗶𝗼 built-in 5000 large-capacity rechargeable battery, when we are trapped in an emergency or our cellphone runs out of power, simply plug your phone or other small electronics into the USB port of this emergency kit for some extra power. Works with most USB powered devices, this survival gear could provide enough emergency power for important calls.
【Never Power Outage with 5 Charging Ways】This emergency solar 𝗵𝗮𝗻𝗱 𝗰𝗿𝗮𝗻𝗸 𝗿𝗮𝗱𝗶𝗼 with multiple power backup options is the best value for survival radio in this market. 5 power sources – 5000 Large Capacity Built-in rechargeable battery, solar, crank, 5V USB Input, 3*aaa battery. No matter what emergency you’re in, it never runs out of electricity!
【Light Your Way with High Illuminated Flashlight & Reading Lamp】It’s a smart choice to have this rechargeable 𝗰𝗿𝗮𝗻𝗸 𝗿𝗮𝗱𝗶𝗼 no matter for indoor or outdoor usage. Provides a 3W camping flashlight and 2.5W reading light, this battery operated radio is designed to light up your darkness when emergencies or bug out, flashlights for emergencies, emergency lights for home power failure.
【Great Reception for AM FM Shortwave Radio】Added a 3.5mm headphone jack and adjustable antenna, this 𝗲𝗺𝗲𝗿𝗴𝗲𝗻𝗰𝘆 𝗳𝗹𝗮𝘀𝗵𝗹𝗶𝗴𝗵𝘁 𝗿𝗮𝗱𝗶𝗼 helps you to enjoy the AM/FM/SW radio with crystal sound and good signal. The big tuning knob makes it easier to tune into your favorite channel manually. The dimension of this portable 𝗮𝗺 𝗳𝗺 𝗿𝗮𝗱𝗶𝗼 is 6.69 x 3.74 x 2.36 inches and weight 1LB, which is surprisingly small and light to carry around.
【Loud SOS Alarm with Red light】Our 𝘄𝗮𝘁𝗲𝗿𝗽𝗿𝗼𝗼𝗳 𝗲𝗺𝗲𝗿𝗴𝗲𝗻𝗰𝘆 𝘄𝗲𝗮𝘁𝗵𝗲𝗿 𝗮𝗹𝗲𝗿𝘁 𝗿𝗮𝗱𝗶𝗼 with versatile functions, a necessary prepper survival tool! When you are in an emergency or need help, you can turn on the flashing red SOS light and alert sound, this portable emergency radio will alarm loudly, and the red light flash meanwhile, which helps you easily get the attention of others.
