Price: $29.99 - $26.99
(as of Feb 25, 2025 18:30:27 UTC – Details)
💡【300LM Long-distance Lighting】300LM solar flashlight with a maximum irradiation distance of 656ft for maximum visibility at night. When you are walking at night, this emergency flashlight can help you well, so that you do not fear the dark!
📻【NOAA Emergency Weather Radio】The weather radio is equipped with a telescopic antenna and built-in professional speakers, and the device will automatically receive and broadcast the emergency weather forecast when it is in power-on mode, so you can be prepared in advance and greatly protect yourself and your family. AM/FM radio allows you to listen to news anytime and anywhere, making life more interesting.
🔋【3 Way Power Sources】The best emergency radio supports 3 charging methods, hand crank charging, direct charging of the built-in rechargeable battery and solar charging. No need to worry about running out of power in the outdoors, but also a must-have tool at home.
⛺【Portable Radio Rechargeable】The portable radio weighs only 0.74 pounds. It is lighter and more versatile than larger emergency lighting devices. The crank radio also has a built-in 3000mAh rechargeable battery that can charge other electronic devices such as cell phones and tablets.
🎁【Free Micro USB Cable + Warranty】The hand crank radio comes with a Micro USB data cable, no need to buy extra. The product also has a 24-month warranty, you can contact our customer service directly if you have any questions, customer satisfaction is our highest pursuit.
