Emergency NOAA Weather Radio with AM/FM and Shortwave Radio Bands: Hand Crank, Solar or Battery Powered, Portable Power Bank, Solar Charger & Flashlight – Rechargeable, Headphone Jack and More!
Price: $69.99
(as of Mar 27, 2025 12:15:25 UTC – Details)
Practical SurvivalPractical Survival
Practical Survival RadioPractical Survival Radio
Early warnings and real time information can save lives.
Whether you are enjoying nature or in times of emergency and stress, having a way to stay informed can mean the difference between coming home or not.
Our Multifunction Emergency Solar/ Hand Crank Radio has been thoroughly tested by US Army Veterans under real life conditions, so you can rely on it whenever and wherever you need it most.
Listen to regular radio or put it on high alert weatherscan mode (which will automatically scan through the 7 NOAA Emergency Channels to give you critical information on time, or listen to Shortwave Radio – a “boots on the ground” means of communication between locals in your area (shortwave radio on this device is listening enabled only).
Box Contents:
1 Emergency Survival Radio.
1 USB Charging Cable.
1 Instruction Manual (please read before charging, turning on or operating the radio for the first time).
practical survivalpractical survival
The Emergency Solar Hand Crank Radio includes a digital LCD display with blue backlighting, with the following push button controls:
POWER: Turns the radio on and off. Transitions from clock display to radio tuner display.MODE: Switches the radio band between AM, FM, Short Wave, and weather band alert mode.TUN: Adjusts the radio frequency up.TUN: Adjusts the radio frequency down.VOL +: Adjusts the radio volume up.VOL – : Adjusts the radio volume down.
The Emergency Solar Hand Crank Radio can be powered using the following sources:
DC power from a USB power source, AC power by adding a USB cable to an AC adaptor (not included).DC car charger by adding a USB to DC car adaptor (not included).Solar power.Hand crank power.Rechargeable Lithium Battery (included).Three AAA batteries (not included).
Emergency RadioEmergency Radio
This emergency survival radio is ideal to help you or a loved one to be prepared at all times.
Carry it on your person or have one in your backpack and one in the car, and make sure you’ll have a reliable source of information and a device charger at the crank of a dynamo.
An American War Veteran owned business, focused on providing practical solutions for real world emergency and survival situations.
We stress test every piece of gear to make sure you can rely on it when you need it most. If you have any issues at all, we’ll make things right – just let us know.
David is an Infantry Veteran with extensive combat experience in stressful survival situations. He knows the extremes some are willing to go to when society breaks down.
He uses this expertise to help select and stress test every piece of gear made by Practical Survival, a brand he partially owns and is one of the founders of.
Warning: When used in the directed manner, this unit has been designed and manufactured to ensure your personal safety. However, improper use can result in potential electrical shock or fire hazards. Please read all safety and operation instructions carefully before use, and keep the included instruction manual handy for future reference. Take special note of all warnings listed in the instructions and do not operate the unit before reading and understanding them.
Features – The Emergency Solar Hand Crank Radio includes the following features: Super bright 3 LED flashlight; AM/FM/SW with Weather Band Feature; Weather Alert Feature (public alert certified); Emergency smart phone/mp3/mp4/USB charger; Backlight digital display; Clock with daily alarm; Audio output; Headphone jack.
Be ready – Whether you are camping, fishing, hiking, traveling, going to the range, going boating, or facing severe weather, tornado watch, hurricane monitoring, ice storms, bad winter, our radio will be a reliable piece of preparedness gear for you. If in your area the risk of having disasters such as tsunamis, earthquakes, power outages, heavy rainstorms are real, now is the time to get ready. If you are concerned with civil turmoil due to supply chain issues, or if you go off grid, have a way to keep your devices charged while staying informed. Perfect as a gift to a friend or family member, or to keep in your bug out bag or shelter, just in case.
Power Sources – This Emergency Solar Hand Crank Radio can be powered by the following sources: DC power from a USB power source, such as a computer; AC power by adding a USB to AC adaptor; DC car charger by adding a USB to DC car adaptor; Solar power; Hand crank power; Rechargeable Lithium Battery; Three AAA batteries.
What’s in the box – 1 Multifunction Emergency Solar/ Hand Crank Radio, 1 Rechargeable 600mAh lithium battery, 1 Instruction Manual, 1 USB Charging Cable (wall adapter not included). If for any reason you aren’t happy with your purchase, get in touch with us and we’ll make it right – each tool comes with a 1 year warranty.
