Emergency NOAA Weather Alert Radio-S.A.M.E. Localized Programming, 23 Country Code&80+ Emergency Alerts, Weather Radio with Battery Backup for Home&Emergency, Present External Antenna & Warning Light
Price: $44.99
(as of Mar 16, 2025 17:15:14 UTC – Details)
【Easy to Programming – S.A.M.E. 】The weather alert radio with the S.A.M.E programming will automatically lock on to your county’s NOAA weather radio signal via the Specific Area Message Encoding which just requires minimal programming from the user. Plus, the SAME weather radio with battery backup function could receive emergency alert information from up to 23 counties as you customize it. Never worry miss any emergency alert from the area you care about with this NOAA weather alert radio.
【Customize Warning Alert You Need】Compared with traditional weather radios, this one has the largest freedom of customization. MD-319 weather alert radio couldn’t only customize the volume to avoid troubling your neighbor, and you also could choose the way that you would like to be alerted: 90 dB Siren Alarm, Voice Alert, or Visual LED flasher. Moreover, the SAME weather radio also could be chosen whether receive up to 80 selectable hazard information. (The alerts with the “ * ” is must open)
【Two Ways To Powered】 AC-110V power of the S.A.M.E radio, which is the main powered way. You could plug the charging cable (included) on the wall to keep the weather alert radio always online. Also, it also powered via 4 AA batteries to be normal use even when power outages. And the settings can still be used as long as switch the power supply within 10S. Never worry about the NOAA emergency weather alert radio will be reset and missing any hazard information(which could save MAX 20 pcs)!
【We Care About You and The One You Love】In order to get a better reception even if you are in the weakly signal area, we present the external antenna and external warning lights as gifts, which could play an important role. Also, please feel free to contact us if you don’t know how to set the county codes or other questions. And if you are not satisfied with this NOAA weather radio, our customer service is here for you 24/7 for anything you need! Your voice drives us to be the best.
