Emergency Hand Crank Radio with LED Flashlight for Emergency, AM/FM NOAA Portable Weather Radio with 2000mAh Power Bank Phone Charger, USB Charged & Solar Power for Camping, Emergency
Price: $19.90
(as of Mar 12, 2025 01:45:17 UTC – Details)
【2000mAh PHONE CHARGER】When we are trapped in an emergency,This emergency radio with a 2000mAh emergency power bank may be our life-saving tool. The emergency portable radio works with most USB powered devices, which could provide enough emergency power for important calls to your family, the emergency services, or for contacting assistance in emergency situations.
【3-WAY POWER SOURCES】The solar crank radios with multiple power backup options are the best choice in the emergency package. 3 Power Source including Hand Crank, Solar Panel, Built-in Li-ion Rechargeable Battery, to make it easier to keep the emergency radio running during a prolonged situation where power is off and batteries have been used up. Never Power outage!
【PORTABLE RADIO WITH FLASHLIGHT】This pocket-sized portable emergency radio’s dimension is 5*1.8*2.4inch and weight 0.5 LB, which is surprisingly small and light. Also, it comes with 1W LED Flashlight, which will cut through the blackness and maximize visibility. Carrying around a large unit is quite difficult when you have to move around during emergencies, this emergency radio is a smart choice.
【CUSTOMER TECHNICAL SUPPORT】Your voice drives us to be the best. We back our emergency weather radio with an 18-months Warranty! If you are not satisfied with this NOAA weather radio, we will provide the solution for you immediately as you contact us. And our customer service is here for you 24/7 for anything you need! NO RISK FOR YOUR PURCHASE!
