Emergency Hand Crank Radio, 4000mAh AM/FM/NOAA Weather Radio, Esky Portable Solar Radios with 3 Modes LED Flashlight, Motion Sensor Reading Lamp & SOS Alarm for Home and Emergency
Price: $45.99
(as of – Details)
Charging Modes Whenever You Need It: No power outage again! The weather radio can be powered by hand crank, solar panel, USB charging cable or replaceable batteries. But for continuous long-term running, it’s better to charge the radios with the provided charging cable. The other 3 charging ways are mostly for emergency power source.
NOAA Weather Radios for Home: Adopted top-grade elements and antenna, the hand crank radio allows to receive the latest emergency weather alerts amongst preset 7 NOAA channels and weather broadcast and disaster information via the AM/FM stations. All you need to do is switch on the power and manually tune to desired channels.
3 Modes Flashlight & Motion Sensor Reading Lamp: Much brighter than other similar ones, this solar radio is a great alternative of flashlight which can constantly work over 10hrs and the farthest lighting range exceeds 10m. Moreover, the emergency crank radio comes with motion sensing reading lamp that can auto turn on when someone walks into its sensing range (3m), and auto-turn off when there is no one within 30 seconds, which can effectively save energy.
Portable Radio With SOS Alarm: If you are an outdoor enthusiast or intended for a journey, just slip this NOAA radio into backpack or suitcase with your belongings and first aid kit, then it’ll definitely help you out of troubles. It’s so sleek and lightweight. When you are in emergency, press SOS button to activate the SOS Alarm searching for help, the SOS alarm is loud enough to quickly catch other’s attention and then you’ll be rescued in time.
