Price: $39.99
(as of Mar 11, 2025 01:45:14 UTC – Details)
Product Parameters
Channel FM、AM、WB (WB band is only supported in the US) Frequency Range FM:76-108Mhz AM:520-1710Khz WB:162.4-162.55 SOS Support manual SOS alarm, support monitoring WB1050 signal automatic alarm Reading light 0.3W reading light, support CCT switching and brightness adjustment Battery Rechargeable lithium 18650 battery 2200mAh, or Max 7000mAh for optional Battery indicator Support 4 battery indicator lights (25%, 50%, 75% ,100%) USB output Support 1A output to charge mobile phone Charging method USB charging 5V/1.1A、0.6W solar charging、Hand crank charging Speaker 3ohm 2W Earphone output 3.5mm earphone output Working voltage 3.0V – 4.2V Working temperature -10℃ – 60℃ Max power consumption 1.55W
Multiple Power Sources: Our Emergency Hand Crank Radio can be powered by a hand crank, solar panel, or USB cable, ensuring that you always have access to essential information and communication. USB Type-C 5V1A charging, 0.6W monocrystalline silicon solar panel charging, hand-cranking charging, with a power indicator.
AM/FM Radio and WEB Weather Alerts: Our Emergency Hand Crank Radio features an AM/FM radio and WEB weather alerts, providing you with up-to-date information on weather conditions and emergency situations.
Bright LED Flashlight and SOS Alarm: Our Emergency Hand Crank Radio also features a bright LED flashlight and SOS alarm, allowing you to signal for help in case of an emergency. High quality reception module, sensitive and stable, strong waveband signal.
Lightweight and Portable with Multi-Function: It is lightweight and portable, making it easy to carry around wherever you go. It’s the perfect choice for camping, hiking, or any outdoor adventure. It can also serve as a reading lamp while reading a book at home.
Stay prepared for emergencies with our reliable and versatile Emergency Hand Crank Radio. With its multiple power sources, communication options, and essential features, it’s the perfect choice for staying connected during emergencies, and perfect combination of functions.
