Emergency Crank Radio,AM/FM NOAA Portable Weather Radio with 6000mAh Emergency Power, with 4 Built-in Cable,1W LED Flashlight,Reading Lamp&SOS Alarm for Home and Outdoor Emergencies(Orange)
Price: $29.99
(as of Jan 12, 2025 22:45:19 UTC – Details)
【6000mAh Emergency Radio With 4 Built-in Cables】Unique from the other emergency radio, this 6000mAh Emergency weather radio isn‘t only has a built-in Micro cable, USB-C cable, and lightning cables, but it also is equipped with USB input cable. Using the built-in cables to charge, the emergency radio with a 6000mAh battery is compatible with iPhone, Android devices, and USB-C most mobile phones and smart devices. Wherever you go, don’t need to carry any extra cables.
【3 Charging Methods】Use the included USB-C cable to connect the input port is the main and the most efficient way to charge this emergency crank radio, which just needs 5-6 hours to be fully charged. Also, we also could charge this NOAA emergency weather radio through the built-in USB cable connection adapter (not included), or could charge this emergency hand crank radio through the crank while in a power outage. Multiple charging methods keep the emergency weather radio always on power.
【Super-Bright Light & SOS Alarm】This emergency flashlight radio has a 3-mode flashlight, you can control the brightness to provide better vision at night. Also included is a 6 LED reading lamp, which has soft lighting that makes the room look very warm, perfect for indoor with the family. If you live in an area prone to storms of all kinds, please keep this emergency radio within handy reach, the SOS Alarm function will let you be rescued quickly if you’re in trouble.
【We Care About What You Care】Nature is unpredictable, but you could buy the emergency radio ahead for the one you love and to earn a critical time before bad weather. We back an 18-month warranty for this emergency crank weather radio. And if you are not satisfied or have any questions about our emergency radio, our customer service is here for you 24/7 for anything you need, such as customer service or refund. If you don’t want to miss this emergency hand crank radio, just pick it up now!
