Price: $17.98
(as of Apr 16, 2025 03:30:23 UTC – Details)
Electric Lunch Box Food Warmer – Herrfilk Portable Food Heater for Car & Home – Leak Proof, Lunch Heating Microwave for Truckers with Removable Stainless Steel Container 1.5 L, 110V/12V[Upgraded]
【SAFTY & FAST PTC HEATING TECHNOLOGY】Using PTC original constant temperature heating, low-consumption heat cycle to keep food at a suitable temperature and keep the moisture of the food. It normally takes 30-50 minutes to warm the food, super efficient and energy-saving. (If the food was taken out of the fridge or where the ambient temperature is low, the heating time should be extended appropriately).
【PACKAGE LIST】Electric lunch box warmer includes: 1x electric lunch box ( 17*10.8*24cm ), 1x insulated lunch carry bag, 1x plastic additional compartment,1x leak-proof seal ring, 1x stainless steel spoon & fork,1x 304 stainless steel inner box, 1x dishcloth, 1x 12V power cord for cars/trucks, 1x 110V for home/office use. Capacity 1.5L.
【LEAK PROOFING】Improved cover design, the cover will not move during use, more tightly covered. Because leak-proof seal ring design is added, it improves the defect of food leakage. Prevent fluid leakage in sloshing car environments.
【MATERIAL & HEATING NOTES】The electric lunch box is made of food grade PP plastic and stainless steel, which is high-temperature resistant, non-toxic, durable, eco-friendly and safe to use. Warm Tips: Please do not clean the heating base with water, and do not add water to the heating base.
【2 IN 1 Car & Home Cable Guide】Electric heating lunch box contains two different plugs: one for Home/Office(110V), one for Car/Truck(12V/24V). Please check our photo guide before use. The Car cable is used on the Right port. The home cable is used on LEFT port. Dont Mix them. Please contact our 24-hours customer service if you need any help.
