Electric Lighter, Switchable Butane Fuel Torch Jet Flame Lighter Electronic Arc Lighter Refillable Butane Lighter 2 in 1,Windproof Plasma USB Rechargeable Lighter (Without Butane Gas)-Silver
Price: $30.99
(as of – Details)
šŸ”„ 怐USB Rechargeable & Battery Indicator怑You can charge this windproof Lighter with a standard micro USB cable in any devices that compatiable with USB port,like computor,laptop,power bank, and adapters etc.the plasma lighter requires about 40-60 minutes for a full charge via the USB cable we supplied,High-quality battery cycle lasts 300~500 charges. It has four LED lights battery display ,It will remind you when you lighter needs to charge at anytime.
šŸ”„ć€Butane Refillable & Adjustment Flame怑This butane lighter with universal refill valve, portable size. It has an adjustment wheel at the bottom, you can easily rotate the adjustment wheel to adjust the flame height. if the valve is too large or too small, it is not conducive to igniting the flame. If you fill the lighter with butane and the ignition fails, you can try to adjust the valve to find a suitable ignition point, and then the lighter will work normally.
šŸ”„ 怐Windproof Design Lighter怑the strong dual-arc easily against any breeze, which is works well even in wind conditions, it can effectively protect the electric pulse arc from being blown out by a strong wind or any wet weather environments.Jet torch flame lighter blue flame is visible in the sun, especially for outdoor indoor activities like kitchen,hiking or BBQ, also for igniting candles,cigars, cigarettes, and fireworks.
šŸ”„ 怐Package List怑1x Jet Torch Flame Lighter & Dual Arc Lighter(2 in 1), 1x USB Charging Cable, 1x Fancy gift box. (Note: During the ignition, there will be the noise of ā€œ zee, zeeā€, which is high-voltage power generation, please don’t worry about that,Lighter is shipped Without gas due to Air Mail regulation.)
