Electric Candle Lighter Plasma Arc Lighters Windproof & Flameless with USB Rechargeable Battery Double Safety Switch (Ruby Red)
Price: $19.99 - $26.99
(as of Apr 10, 2025 19:45:20 UTC – Details)
【Efficient Ignition Method】- Comparing with traditional lighters and matches, it can ignite candles, stoves, fireworks and etc. in a more convenient, safer and faster manner. No flame, thus it won’t burn your fingers, and no more harmful butane!
【USB Rechargeable】- No need to refill the lighter ever! Built-in large capacity battery, and power indicator lights to remind you when it should be charged. The portable USB cable can connect to power source such as computers, power bank and etc.
【Born For Safer Ignition】- 7s Auto Off: The electric arc will automatically turn off after 7 seconds per use. Double safety switch: The power button is under the safety switch, avoiding accidental touches of the ignition button when you put it in your pocket or bag. During ignition, there will be a “zee,zee” noise, which is a normal operation sound, please use with ease.
【Excellent Material】- The contacts on the head uses alumina ceramic, which is durable and high temperature resistant. The aluminum alloy shell body allows the lighter quickly dissipate heat after using.
