EF ECOFLOW Solar Generator DELTA2 with 220W Solar Panel, LFP(LiFePO4) Battery, Fast Charging, Portable Power Station for Home Backup Power, Camping & RVs
Price: $1,699.00
(as of Mar 09, 2025 07:30:27 UTC – Details)
Built to Last 6x Longer. Its LFP battery chemistry makes for a portable power station with a 3000+ cycle life. Enough for years on end of use. With a sophisticated BMS, you can go easy knowing its an auto-regulating portable battery to keep you safe.
Power Almost Anything. Solar powered generator have come a long way. Power all your appliances with 1800W output, that’s on par with outdoor generators without the fumes or noise. With 15 outlets and its huge output, you can power 90% of your appliances.
Expandable Capacity from 1-3kWh. With the standalone portable power station sporting 1kWh, you can add on extra batteries to reach up to 3kWh. Ideal for camping, RVs or home backup power.
What you Get. DELTA 2 Power station, 220W Solar panel, Adjustable kickstand case, AC charging cable, Car charging cable, Solar charging cable, DC5521 to DC5525 cable, User manual, and an exclusive 5 year warranty.
*DELTA 2 and 220W Portable Solar Panel will be shipped separately.
