EF ECOFLOW Solar Generator DELTA 1260Wh with 160W Solar Panel, 6 X 1800W (3300W Surge) AC Outlets, Portable Power Station for Outdoors Camping RV High-Power Appliances Emergency
Price: $1,448.00
(as of – Details)
6 x 1800W AC OUTLETS AND 1260Wh CAPACITY: DELTA can power up to 13 devices simultaneously with multiple outlet options, including 6 pure sine wave AC outlets. It offers up to 1260Wh power, which is ideal for home backup situations where you need to power smartphones, laptops, refrigerators, and more.
RECHARGE FROM 0% TO 80% WITHIN 1 HOUR: The patented EcoFlow X-Stream technology enables you to charge the DELTA from 0-80% within 1 hour and offers a full charge in just 2 hours. Use the EcoFlow 160W Solar Panel to charge DELTA in 10.5-21 hours at a recharging rate of 10-65V/10A max, 400W max input.
INTELLIGENT SOLAR CHARGING: The EcoFlow 160W Solar Panel has a high conversion efficiency of 21-22%. Combine the 160W Solar Panel with an EcoFlow Power station to enjoy improved solar charging in cold and cloudy environments.
Waterproof & Durable: The 160W solar panel is waterproof to endure all weather conditions, ideal for outdoor activities such as camping, climbing, hiking. You can submerge the panel in water for up to 30 minutes with no detrimental effect to the product.
