Price: $2,899.00
(as of Apr 05, 2025 15:15:19 UTC – Details)
EcoFlow's DELTA Series is recognized by some of the most prestigious international awards. The flagship product of the Series – DELTA Pro, was named in TIME's list of 100 Best Inventions of 2021. It also won the 2022 Red Dot Design Award along with its ecosystem accessories. Adding to the DELTA Series's legacy, the 2022 iF DESIGN AWARD named the DELTA Pro, DELTA Max, 400W Solar Panel, and Smart Generator the winners in the product discipline.
【Astonishing Efficiency】When paired with DELTA Pro, the 400W portable solar panel utilizes the MPPT algorithm to achieve optimal efficiency no matter when it rains or shines. Where solar panels are concerned, its conversion rate of 22.4% is astonishing. With a single 400W panel, the large power bank gets a full recharge in 11-22hours and with the 3x400W ones, it gets a full recharge in 3.5 – 7 hours.
【Light and Durable】The EcoFlow 400W Solar Panel is foldable and comes with an adjustable carry case. Weighing in at only 16kg (35.3lbs), it can be easily packed up and carried with you, no matter where you go. Made from layers of flexible EVA and tough fibreglass, it also comes with a IP68 Waterproof rating, meaning it is dust and water tight.
【Portable RV Power】Bid farewell to noisy, fume-filled gas generators and relish peaceful, green, maintenance-free power wherever your RV adventures take you. Charge your camping accessories, or plug into a shore power outlet to directly power your RV’s electrical system. Please note that shore power cable is not included.
【15 Versatile Outputs】DELTA Pro includes 15 outlets and ports: 5*AC outlets, 4*USB-A ports, 2*USB-C ports, 2*DC ports, 1*car power output and 1*Anderson port. Power all your devices such as cell phone, iPad, tablet, camera, radio, projector, night light, mini fan and so on.
【Smart App Control】Integrate DELTA Pro with your home using the EcoFlow Smart Home Panel, then use the EcoFlow app to break down your energy habits or customize your energy usage to fit your needs. The EcoFlow DELTA Pro ecosystem stores energy during the day, reducing your reliance on the grid and lowering your bills by combating peak energy rates.
