EF ECOFLOW Portable Power Station DELTA Max 2000, 2016Wh Expandable Capacity Portable Generator, Solar Generator for Home Backup, Emergency, Outdoor Camping
Price: $3,199.00
(as of Mar 17, 2025 12:00:31 UTC – Details)
2-6kWh Expandable Capacity. DELTA Max’s large 2kWh capacity keeps your home appliances running during a blackout. Expand up to 6kWh with Extra Batteries, keeping your home powered on in any emergency.
Power Heavy-duty Devices with 2400W Output. 2400W output to power up to 15 devices at once. Power 3400W appliances with X-Boost on. That means during a power outage or blackout, you can continue to power your fridge, microwave, dryer, and more. Ideal power generator for backup power.
Solar Charge in as fast as 2.5 Hrs. Connect solar panels of up to 800W to keep DELTA Max running even when there’s an outage. Compared to gas generator, the cost of gas, noisy operation, maintenance make DELTA Max a good long-term investment.
Monitor & Control from the EcoFlow App. Take control of your DELTA Max and quick-view stats right from your phone. Customize settings such as charging speeds and Dual Fuel Generator auto-start levels to fit your power needs.
Plug and Play Home Backup Power. Simply connect DELTA Max to your power inlet box for instant home backup when the power goes down.
