EF ECOFLOW 3600Wh Portable Power Station with 3600Wh Extra Battery*2, 120V Lifepo4 Power Station, Home Battery Backup with Expandable Capacity, Solar Generator for Home Use, Blackout, Camping, RV
Price: $7,099.00 - $6,299.00
(as of Mar 22, 2025 15:00:29 UTC – Details)
【X-Stream Fast Charging】Fully recharge the DELTA Pro in 1.8 hrs with 240V outlets(3000W), 2.7 hrs with 1800W wall outlets or solar charged in 3.5-7 hours with 3*400W solar panels thanks to the industry-leading solar conversion efficiency of up to 23%. Ideal for juicing up the battery between short outages. EcoFlow’s X-Stream charging technology isn’t just fast, it’s safe too with the battery management system.
【5 Ways to Charge】Pick from EV station charging, solar, wall outlets, using the smart outdoor generator or via a car outlet. Faster than any other 3000 watt solar generator. Keep going for miles when your electric vehicle runs out of battery. Either at home or on the go, DELTA Pro will have you back on the road in no time.
【Smart App Control】Integrate DELTA Pro with your home using the EcoFlow Smart Home Panel, then use the EcoFlow app to break down your energy habits or customize your energy usage to fit your needs. The EcoFlow DELTA Pro ecosystem stores energy during the day, reducing your reliance on the grid and lowering your bills by combating peak energy rates.
【Portable RV Power】Bid farewell to noisy, fume-filled gas generators and relish peaceful, green, maintenance-free power wherever your RV adventures take you. Charge your camping accessories, or plug into a shore power outlet to directly power your RV’s electrical system. Please note that shore power cable is not included.
【15 Versatile Outputs】DELTA Pro includes 15 outlets and ports: 5*AC outlets, 4*USB-A ports, 2*USB-C ports, 2*DC ports, 1*car power output and 1*Anderson port. Power all your devices such as cell phone, iPad, tablet, camera, radio, projector, night light, mini fan and so on.
