Price: $18.95 - $7.99
(as of Aug 31, 2024 12:00:24 UTC – Details)
Do You Find Keeping Car Keys In Your Pockets Rather Troublesome?
While it’s the norm for many drivers, keeping keys in their pockets isn’t for everyone. For one, fishing them out of tight pockets can be a challenge. It can be quite inconvenient, too, if you need to constantly take them out and put them back in. Plus, those metal teeth can scratch and damage your phone or wallet.
Carrying and using car keys shouldn’t be this complicated. With a little clever engineering and design, we’ve transformed the ordinary lanyard to make your drives much easier.
This Magnetic Keyring with Lanyard by EDO GOT presents a secure and convenient way of putting away your keys!
A More Efficient Way Of Carrying Keys
Our magnetic keyring saves you from the hassle of fishing out your keys from your different pockets or bags. As it comes with a lanyard, you can simply wear your keys on your neck, pull off the key when you need to start your car, and then snap it back on after turning off the engine. There’s nearly no recoil when disconnecting the magnet.
When the day ends, you can detach the lobster hook from the magnet and attach it to the rest of your keys.
Hook It To Your Belt Loop
Not keen on wearing your keys around your neck? Our magnetic keyring comes with an aluminum matte black carabiner so you can clip your keys to your belt loops or high-visibility vest.
All you need to do is detach the keyring from the lobster hook that connects it to the lanyard, then transfer it to any of the two rings on the carabiner. The carabiner is equipped with a strong spring that locks the gate securely.
Comfortable & Classy
The magnetic keyring is attached to a black lanyard that’s about 49cm long and 2cm wide. The silky polyester fabric feels nice on the skin and is non-irritating, making it comfortable to wear all day long.
The ends of the lanyard, as well as the zinc alloy lobster hook, are secured with a genuine brown leather strap. It’s embossed with the brand’s logo, giving it a stylish flair.
More Reasons to Choose the EDO GOT Magnetic Keyring with Lanyard:
Reliable Attachment, Thoughtful Design
The magnets are encased in zinc alloy casings that have grooves to prevent them from moving. The lobster hooks are made from steel according to a specific thickness for durability. The hooks, keyrings, and magnet buckles are electroplated so they will not rust.
Aside from being compatible with other magnetic keyrings, the magnet casings also have rings around the opening. These prevent your fingers from getting pinched when the magnets connect.
Make Work Easier
As a parcel and food delivery worker, you already have a lot on your plate. Looking for your keys shouldn’t add to your stress. This is why we created this magnetic keyring.
As such, you can wear your car key around your neck or hook it to your vest, whichever works best for you. Our lanyard also leaves your hands available so you can carry more bags and boxes and check your phone for delivery details without your keys getting in the way.
Beyond Work
This magnetic keyring isn’t just for holding and securing keys. With the magnets’ strong pulling force, the carabiner, and the device’s overall quality, you can use it to carry a variety of other items.
Use it to hold your water bottle, umbrella, or other items while hiking or mountaineering. You can even use it to hold tools, flashlights, and other EDC items.
Please note that this product is NOT a toy. For safety, keep it away from pets and children aged 13 and under.
Product Dimensions ‏ : ‎ 23.23 x 0.79 x 0.79 inches; 2.29 Ounces
Department ‏ : ‎ unisex-adult
Date First Available ‏ : ‎ December 13, 2022
Manufacturer ‏ : ‎ EDO GOT
ASIN ‏ : ‎ B0BNBHQ3YS
Magnetic closure
Designed For Food Delivery Drivers – Fumble less and save time on the road. Our magnetic key holder comes with a lanyard and aluminum matte black carabiner so you can keep essentials around your neck or belt loop.
Built Tough – With strong magnets, this magnetic quick release keychain has a pulling force of 6.6 lbs/3Kg. The steel clasps are durable and won’t easily open. All metal parts are electroplated and rust-proof.
No More Pinched Fingers – This lanyard for keys is designed with a ring around the magnet’s casing. This unique design helps prevent fingers from getting pinched when you attach the magnets together.
Quick & Easy to Use – Attaching the ring back to the key lanyard is a cinch. Even if one magnet is positioned at an odd angle, the other will flip it over and connect instead of pushing it away.
Buy With Confidence – We’re confident you’re going to love our delivery accessories. But if within 30 days you’re not 100% satisfied with our magnetic keychain lanyard, we’ll give you a replacement or return for a full refund.
