Price: $15.99 - $12.99
(as of Apr 19, 2025 22:15:19 UTC – Details)
● Product color: Carbon black
● Product size: 18.6cm(height)*6.6cm(bottom)*8.8cm(top)
● Material: High quality ABS plastic and PC
Large cup holder extendable size is 2.87-5.90” in diameter
Small cup holder for bottles and cups below 2.83” in diameter
❤ Package Included ● 2-IN-1 Car Cup Holder Expander Adapter
● Cushion foam pad * 2
❤ Note
– Since the cup holder is thin and long and consists of two parts, please compare the height of the cup body and the cup holder before ordering. This cup holder is not suitable for a particularly long and thin cup body, like 500ml or more of water or bottle.
– Adapter works best with bottles/cups 3.0″-5.9″ in diameter, fits most 20 oz water bottles. As car water bottle holder height only has 8.4cm, it is recommended not to store too high cups or water bottles.
– If there is a large gap between the base and the support, more rubber pads are needed to fill the extra bottom spacing. I recommend using weatherproof tape to fill in the extra space to secure it in the car cup holder.
【360° Rotating Design】The base of the upper cup holder can rotate flexibly in 360 degrees, One car cup holder can be replaced by two. And the position can be shifted and adjusted according to the space of the car body, save car interior space.
【Extendable & Non-Silp Base】The adjustable base expands from 2.5” to 3.7”make sure that the base is firmly installed on various car cup holders and will not fall, and the silicone pad on the expansion piece provides more powerful grip.
【Multi-Functional】This extra car cup holder expander is suitable for most models, and the adjustable upper cup holder is easy to store mobile phones, sandwiches, snacks and potato chips. It is recommended not to store too high cups or water bottles.
Tip: Please check the internal dimensions of your car cup holder!!! The original vehicle must be a ROUND cup holder, and the diameter of the cup holder mouth of your vehicle must be between 2.4 and 3 inches. Please confirm before purchasing.
