Price: $16.66
(as of – Details)
Feature: Items In This Store Are Designed With Full-Width Printing And Double-Sided Printing. The Outer Shell Is Ps, And The Inner Layer Is Made Of High-Quality 304 Stainless Steel. Product Specification Size: Bottom Cover Width 2.5in, Top Cover Width 3.3in, Height 6.6in Our Products Are Also Super Easy To Clean And Can Be Used Over And Over Again. After Receiving It, Scald It With Boiling Water Before Using It, Which Can Remove The Dust Generated During The Cup Making Process. Our Coffee Mugs Are Perfect For Any Indoor Or Outdoor Setting. Perfect For Drinking At Home, Beach, Lakeside, Pool, Office, Party, Rv Trips, Cabin Trips, Camping, Hiking, Picnics, Bbqs Whether You Want To Keep Your Sweet Tea Cool On A Hot Summer Day Or Your Hot Coffee Hot On Your Commute, This Coffee Mug Has You Covered. Suitable For All Kinds Of Hot And Cold Drinks. Our Product Design Is Very Beautiful And The Quality Is Very Good, It Is A Perfect Gift For Your Sister
【Product Specification And Size】The Bottom Cover Is 2.5in Wide, The Top Cover Is 3.3in Wide, And The Height Is 6.6in
【Product Performance】Humanized Design, Compact, Watertight, Safe, Safe To Use, Easy To Carry, Lid Outlet Switch, Streamlined Cup Body Design, Beautiful And Practical, Strong Flexibility, High Temperature Resistance, Environmentally Friendly Materials, Heat Insulation. The Bottom Of The Cup Is Thickened And Non-Slip Design. Easy To Use, Easy To Store, And Easy To Access. The Airtight Design Provides You With A Cup Of Fragrant Hot Tea During Your Tiring Travel!
Accessory Structure Plastic Shell, Stainless Steel Liner, Rotating Base, Buckle Cover
【Washing Instructions】Easy To Clean And Can Be Used Repeatedly. After Receiving It, Scald It With Boiling Water Before Using It, Which Can Remove The Dust Generated During The Production Process Of The Cup.
