Price: $13.29
(as of Apr 06, 2025 09:45:17 UTC – Details)
Warning
1.Due to air mail regulation, the lighter is EMPTY before shipping out.
Please refill with high quality butane gas before using.
2.When you adjust the flame to lowest setting, there will be no flame for safety design.
While on highest setting, the flame will last for 1-2 seconds after releasing the ignition button because there will be a little remaining gas on the burners, please pay attention.
We recommend to adjust the flame to medium level when using it.
4.Prohibited to face the body or inflammable things when using.
5.Keep lighter beyond the reach of children.
6.Burning Time: No more than 10 seconds.
7.DO NOT put it under high temperature (<50℃)
How to refill your lighter:
1.Before refilling a lighter,please drain any remaining fuel from the lighter. Using the small screwdriver press the fuel-refilling nozzle to remove the leftover fuel.
2.Turn the flame regulator until it stops to turn off the fuel flow before refueling.
3.Point the fuel nozzle up and push the container of fuel into the lighter. Turn the fuel nozzle down and wait while the lighter refills.
It is important not to pump the fuel can into the lighter while refueling because this may cause the fuel tank to burst.
4. Once the lighter is refilled, allow it to rest until the fuel becomes room temperature.
Butane fuel is cold while refilling. It will expand as it gets to room temperature.
5. Turn the flame size regulator back 1/2 turn counter clockwise. Attempt to light the lighter.
If the lighter won’t light, turn the regulator another 1/4 turn and try again.
Keep adjusting the regulator in 1/4 turns until the lighter lights
Package includes 1x jet torch lighter
Should you have any questions about the product or service,please kindly contact us
via email in advance.Thank you.
✅【Transparent Visible Window】 — Visible and transparent windows. The gas balance is at a glance to add LED blue lights to make the lighter more cool and more personality.
✅【Adjustable & Refillable】:This cool butane torch lighter?s flame size can be easily adjusted by the bottom dial. Convenient and worry-free. Universal refill valve for easy butane refill.
✅【Widely Versatile】:This Butane Refillable Lighter is Perfect as outdoor activities such as hiking, bonfire, camping trips, camping stove, make fire outdoors and so on, and also Useful Lighting your Fireplace, Candles, for Hobby, for Multiple Camping Applications.
✅【What You Get】:1 x Jet Flame Torch Lighter,This is probably a perfect gift for birthday, Anniversary, Thanksgiving, Christmas,New Year, Valentines Day,friends, family and more.(Note: Lighter is shipped Without gas due to Air Mail regulation.the lighter DOES NOT come filled with butane.)
