DLNRG R300 299Wh Portable Power Station, 300W Pure Sine Wave Solar Generator 93437mAh Backup LiFePO4 Battery 110V 2 AC Outlets,PD 60W USB-C in/out,Dual 12V/120W Ports outdoor generator for Camping,RV,CPAP Black
Price: $259.99 - $65.99
(as of Mar 15, 2025 20:30:27 UTC – Details)
Wattage :
300 watts
【Universal Compatibility with Pure Sine Wave AC Outlets】Its Output Waveform is Same As the AC Power Waveform of Mains Power Grid Provided by the Electric Utility Which Delivers a Smoothly-varying Sine Wave for Sensitive Electronics.The Best Backup Power for Off-grid Life with Lower THD,Less Interference,Strong Loads Capability.The Solar Battery Generator does Automatically Sense Overload Condition and Shuts Down AC Power When the Load Exceeds 300W.
【LiFePO4 Battery Built-in BMS&MPPT for Multi-protection】The Advantage of LiFePO4 Batteries Solar Generator Better than Lithium Battery is Thermal and Chemical Stability,Which Improves Battery Safety and Durability,Offers 2000+ Longer Life Cycles.The Solar Power Generator built-in MPPT Controller Enables Solar Panel to Operate at its Max Power Point for the Power Station to be Recharged at its Highest Efficiency to Save More Electricity Bills.
【Supports 4 Ways to Recharging】1.Wall AC Outlet in 7.5H; 2.Solar Panel in 6H; 3.Car Socket in 9H; 4.PD 60W USB-C Port in 5H;Please Note:Solar Panel Sold Separately,the Rated Voltage Must be < 23.5V. Do not Supports More than 2 Ways to Recharging At the Same Time.
【Quality Warranty and What you get】UL Certified LiFePO4 Battery Solar Generator,Any Questions or Dissatisfactions with Your Purchase,24H x 7D Friendly Technical Customer Service,DLNRG Guarantee you refund within 30 Days,and 18-Month Product Replacement Warranty;Packing List:1xDLNRG R300 Portable Power Station;1xAC Power Adapter;1xMC4 Solar Panel Charging Cable;1xCar Cagaritte lighter Charging Cable;1xUser Manual.
