Price: $99.99
(as of Jan 10, 2025 11:15:31 UTC – Details)
A wireless connection between the camera and monitor means that with these systems, there
is no need to run cabling through your vehicle. This is usually the most difficult part of rear
view camera installation and cutting it out, cuts the install time in half! This wireless systems
also come with waterproof wireless backup cameras and excellent night vision to ensure
these systems provide the best quality image as well as an easy install.
Q/A
How long does it take to install a wireless backup camera?
Installation time varies based on vehicle but a standard one camera system should take under one
hour to install.
What distance does the wireless transmission cover?
2.4 GHz wireless camera range is 30 feet when inside an RV and up to 190 feet in open space
Which vehicles do your wireless systems work on? Can I use the wireless systems
as a backup camera for car applications?
This wireless backup cameras are best for trailer applications. Although they can also be used as a
car backup camera, vehicles like fifth wheels, travel trailers and semi-trucks, where wired
systems are difficult to install, is where wireless really shines.
Do your rear camera systems get interference from other wireless devices?
No, our systems use 2.4G Digital wireless signal that guarantees no interference from other
devices.
If it’s wireless, why do we have to run a wire to the camera?
The connection between the camera and monitor is wireless, however, each part still needs to
receive power. All you need to run wires for is to get power going to the camera.
What is the power source for a wireless backup camera?
The camera needs just DC12V-24V of power. For this, you can tap into power for the reverse lights
or the running lights which you can find at the back of every vehicle.
【IP69k Waterproof Wireless Backup Camera with 120° Wide Viewing Angle】:Reducing the blind area when reversing; IPS 7’’ monitor provides you a clear image back of your car and without delay, 16 Infrared Lights and CCD Sensor will present superior Night vision for you
【Do It By Yourself】:Monitor installation just takes 2 minutes, Camera can be installed within 40 minutes as long as you can find out the power cord quickly
【Wide Application】:Voltage Range From DC12V-24V, Most of the Vehicle, Such as RV/ Trailer/Truck/5th Wheel/Bus/Motorhome
【Worry-free after sales service】:30-day money-back guarantee and 1-year warranty. 24 hours after-sales service and Professional technician team is available via our service email.
