DEGEN DE13 FM AM SW Crank Dynamo Solar Power Bank Emergency Radio with LED Flashlight A0798A World Receiver
Price: $9.95
(as of Apr 11, 2025 15:45:22 UTC – Details)
Why choose DEGEN DE13 Eradio?
1.Cranking Dynamo、Slar Power Supply
2. Red LED Light (Flashes) 、 Alarm Fuction
3. Flashlight with 3 LED lights
4. Cell Phone, MP3、MP4 Charging Jack ( Standard USB port)
5.External Adaptor Jack(MINI USB 5 Pin) Jack)
6. Built-in Speaker
7. Earphone Jack (D3.5mm)
8. Power Sources: NI-MH Battery, 3 X AAA Alkaline batteries or Solar Power
9. Charged by: Cranking Dynamo, External Adaptor, Computer or Solar Power
Frequency range:
FM: 87~108 MHz
MW: 520~1710 KHz
SW1: 5.80~10.00 MHz
SW2: 11.6~18.2 MHz
Sensitivity:
FM≤5uV
MW≤2.5mv/m
SW≤50uV
Signal selection: ≥40dB
Output power: about 100mW
Max. volume Output Current: 120mA
Speaker: D50mm
Earphones: D3.5mm
2.Small, compact and light model with a fresh green look, weight 0.256KG (excluding battery), size: 13.3*6.2*4.7CM. Easy to carry so you’ll hardly notice it’s in your bag; with alarm function and flashlight function. Suitable for use in various scenarios, outdoor, garden, park, camping, fishing and other scenarios.
3.Three power supply methods, rechargeable battery power, AAA (7) battery power, solar power, four charging methods, cranking Hand crank power generation, solar power charging, USB charging, computer charging, also can use DE13 for mobile phones, MP3, MP4. Rechargeable, which can reduce the problem of power being unavailable in outdoor emergency situations.
4.It features a high quality speaker and IC with good reception, and can be tuned to FM/WM/SW. It has two easy-to-control turntables: one for the mixer and the other for the volume control, and comes with an antenna with enhanced reception. Good extensibility to help you get a better signal wherever you are.
5.What you get: DEGEN DE13 Radio, Rechargeable Battery, USB Charging Cable, Wrist Band, English Manual, 12 months of hassle-free service and excellent customer service.
