Price: $28.72
(as of Jan 27, 2025 13:30:30 UTC – Details)
Have you ever experienced it?
No power, no light, no signal, no contact with the outside world, etc.
Here, NO worries with this newest emergency weather radio with TF card function.
This emergency hand-crank radio not only looks good, but also has stronger performance.
All-in-one emergency weather radio that worth buying.
With the emergency radio, you are equivalent to owning these:
Weather alert radio, AM/FM radio, LCD display radio,Flashlight, SOS alarm, Cellphone power bank, a clock.
Such an innovative and multi functional emergency radio,How could you not own one?
The threat of nature? We will never fear!
Have you experienced snowstorms, wildfires, tornadoes, and other horrible natural threats?
Nature sometimes has stretched out its magic claw to us, but we still have to face it bravely.
Our emergency hand crank radio will always be your savior.
With Built-in highly sensitive antenna,this emergency weather radio can receive 7 NOAA stations excellently. Just keep it with your hands and get the latest and most useful weather reports from 7 NOAA channels. Strongly support to receive AM/FM/WB, the stations you want to listen to are in your hands.AM/FM channel lets you listen without barriers and enjoy your favorite stations.
Whenever you need it, it always helps you. You will be fearless to the advent of natural disasters with this newest weather emergency radio.
Super Flashlight and Loud SOS
No one found you? Never happen!
1W LED Flashlight is pretty bright- 120 lumen that can provide light to a wide area and better vision when you are in the dark.
Loud SOS alarm is a good lifeguard for faster help in danger or emergency.
When you need help, you’ll be glad to have this emergency radio with SOS alarm and flashlight.
2000 mAh Phone Charger
As a reliable weather radio, it can also serve as the power bank to charge your phone or other devices in an emergency, allowing you to keep in touch with the outside world.
Also,after fully charged, the weather emergency radio supports LED lighting for more than 7h and broadcast for more than 20h.
The long standby time allows you to use it with confidence.
Alarm clock
Want to know the time? Set reminders? Come on!
This weather radio can not only display the time at the moment, but also set an alarm clock as a reminder, making it a portable alarm clock radio.
When you set the alarm clock at night, it will remind you to wake up the next day, and then you could turn on AM/FM to listen to your favorite radio station. A wonderful day begins from this perfect alarm ringtone!
Is it just an emergency weather radio?
No! It’s time to emphasize its role as a retro multi-functional speaker!
For these,you could choose it to create a relaxed and warm atmosphere with family or as a special and impressive gift to friends.
This retro radio has AUX player,TF card player and USB Flash Drive. Plus,the latter two have memorize playback function.
You will always be remembered with such special and impressive gift!
Solar Power
Power off? Impossible!
The solar panel fully receives the sunlight to run the radio, which is useful and convenient.This charging option is very needed in an emergency.
Hand Crank
The crank power is unlimited, ensuring you have power whenever and wherever.
Rotate the handle either clockwise or counterclockwise for 1 minute at the speed of 130 rpm to get power.
USB Charging
Connecting the included USB cable to the proper adapter(Not Included)to charge the internal built-in rechargeable Battery. When the emergency radio is fully charged,it can play 20-22 hours based on middle volume or the flashlight can be used 7-8 hours.
Historic and innovative Retro Emergency Radio
We have focused on making emergency radios for many years, and we have been exploring and pursuing continuously, with the goal of providing customers with high-quality radios. This radio combines emergency radio with TF card. which is a huge innovation.
Package Content
1 x Emergency Weather Radio1 x User Manual1 x Micro USB Charging Cable
Specifications FM:87-108MHZ AM:520-1710 KHz WB:162.400-162.550KHZ NOAA Weather:1–7 Dimensions:128*57*98 mm Weight:395 g Working Voltage: 2.7-4.2 V Speaker:8W 4Ω
【Super Bright Flashlight & SOS Alarm】NO POWER?NO LIGHT? CANNOT ASK HELP FOR OUTSIDE WORLD? Don’t worry, this emergency flashlight radio could help you. A 120LM super bright flashlight by the hand crank radio can be used for emergency and give you enough brightness. Also, this emergency radio equipped with SOS function. Just turn on the SOS alarm if you need some help in the outdoor. Take this emergency radio in your emergency bag, and you won’t regret having it.
【3 Ways To Power 2000mAh Battery】Hazard weather always leads to power outages. This emergency radio has a built-in 2000mAh battery, which can support 3 charging methods: Micro USB charging, solar panels, and hand crank. Also, it also could be the backup power for your mobile phone, allowing you to get the weather signal or keep in touch with your friends. Absolutely it is an essential device if you are in an emergency, or when there is a power outage.
【Excellent Music Player】Just an emergency weather radio? No, it also is hand crank radio with excellent sound quality for you to enjoy music. It supports:TF card player, AUX output player, USB flash drive. Such an superior sound quality will bring you a feast of hearing, which super useful for the party, family gathering, relaxing and dancing. Stay happy to pick this portable radio with you.
【Highly Cost Effective & Worry-Free】You can’t found the weather radio with alarm clock in the weather radio market with this price range. Also, our emergency radio has helped more than 10,000,000 USA Civilians to live through the hurricane, tornadoes and snowstorm season, like “Dorian”, “Harvey, “Irma”, etc. An 18-month Warranty and 24/7 customer service, which could ensure you no risk to purchase. Don’t hesitate to buy this solar radio now!
