DaringSnail 2000mAh Emergency Weather Radio, Crank Portable Solar Retro Radio with Emergency Power Bank, NOAA/AM/FM, Flashlight, Support Bluetooth 5.0/TF Card/Earphone Jack, for Outdoor or Emergency
Price: $29.99
(as of Feb 27, 2025 09:45:14 UTC – Details)
【Retro Bluetooth Speaker】Equipped with Bluetooth 5.0 and an excellent stereo bass, this AM FM radio could work excellent as a Bluetooth speaker, which could connect quickly to a device such as your phone or other electronic devices within 30 feet, to play your favorite music crystal clear. Meanwhile, the retro crank radio also can recognize up to 32G TF card playback and supports a 3.5mm earphone Jack, allowing you to feel the surging of music as if the sound is on the scene.
【2000mAh Emergency Power Bank】While we were trapped in the power outage, the emergency weather radio with a 2000mAh emergency power bank would be far more reliable than the others device, which could provide enough sufficient emergency power for you to make important calls to your family or call for help. Meanwhile, the emergency radio is equipped with a 1W bright flashlight that could brighten the darkness around you, to get help faster. Keep one in your bag, let you away from danger.
【3 Power Charging Options】This emergency NOAA weather radio with 2000 mAh lithium-ion rechargeable battery, which not only could be charged via the Micro USB Cable to keep the playback time of the solar crank radio up to 16 hours. The Hand Crank and Solar Panel also could provide enough power to keep the crank radio on until the power back. Meanwhile, the 4 electric label allowing you to track remaining power at any time clearly. Never lost the electricity during the emergency!
【No Risk For Your Purchase】In the past years, Our emergency radio has helped more than 10,000,000 USA Civilians to live through the hurricane, tornadoes and snowstorm season, like “Dorian”, “Harvey, “Irma”, etc. Your voice drives us to be the best. We back our emergency weather radio with 18-months Warranty! If you are not satisfied with this NOAA weather radio, we can refund you immediately as you contact us. And our customer service is here for you 24/7 for anything you need!
