Price: $59.99 - $50.22
(as of Aug 21, 2024 10:30:39 UTC – Details)
COSORI Lite 2.1-Quart Mini Air Fryer
This Mini Air Fryer allows for precise meal portions with its compact design, occupying minimal counter space. With 4 one-touch customizable cooking functions work noiselessly and 30 online recipe options, cooking is made effortless.
Specifications:
Model: CAF-LI211
Capacity: 2.1 Qt
Temp Range: 170°F–400°F
Time Range: 0-60 min
Basket Dimensions(D x W x H): 5.9 x 6.2 x 3.5 in(Almost size of adult’s hand)
Product Dimensions(D x W x H): 10.1 x 8.3 x 10.5 in
Weight: 4.87 lb / 2.21 kg
Rated Power: 900W
Power Supply: AC 120V, 60Hz
About Liners:
This Air Fryer has a 5.9 x 6.2 x 3.5″ dishwasher-safe basket, you can also choose to get a liner to keep it clean.
You can search “air fryer liners 2-3qt” on Amazon, these liners will fits this small air fryer well. Or purchase our COSORI papaer liners “B0BSFP5989”, but better to fold it when use in case of touch to the heat element on the top causing it to burn.
Test Run:
In order to make sure the air fryer is working correctly and remove potential odors from the manufacturing process, please follow the instructions in the manual for the Test Run before cooking with your air fryer.
2.1-Qt Capacity: This small air fryer is perfect for single serving items like sides, snacks, wings, and more.
Compact and Portable: Weighing in at less than 5 pounds, this mini air fryer is designed to be easily stored and carried with its sleek, compact design.
4 Cooking Functions: Choose from Air Fry, Roast, Bake, or Reheat, you can easily customize your cooking for your favorite foods.
The Quietest Operation: This airfryer cooks with noise levels less than 48dB, which is quieter than any other COSORI model. You can now cook your favorite foods without the distraction of annoying or disruptive noise.
Fast & Convenient: Even with no preheating needed, this air fryer cooks frozen food to crispy perfection in a matter of minutes at temperatures ranging from 170–400°F.
Up to 97% Less Oil: Enjoy crispy textures with up to 97% less oil than traditional frying.
Included Recipes: Enjoy 30 original recipes created by our chefs for your air fryer on the free VeSync app.
Dishwasher-Safe: Nonstick, BPA-Free accessories are easy to clean in the dishwasher.
A Great Gift: Give the foodies in your life the perfect-sized air fryer for fresh and crispy snacks.
Notification: This Air Fryer is ETL-Listed with a power rating of 120V / 900W, a temperature range of 170F°–400°F, and a 1-60 minute timer. Please note that this voltage only applies to the US and Canada.
