Cobra MR HH350 FLT Handheld Floating VHF Radio – 6 Watt, Submersible, Noise Cancelling Mic, Backlit LCD Display, NOAA Weather, and Memory Scan, Grey
Price: $197.87
(as of Apr 18, 2025 20:00:37 UTC – Details)
[sc name="tester"][/sc]
The best value in our handheld VHF radio line up! Backed by 50 years of Cobra quality, this floating radio has an orange core for higher visibility and is easy to retrieve if dropped overboard. It features 6 Watts of power for longer range communications and full access to all NOAA weather channels and alarm tones for weather emergencies. It also includes all of the core features like Noise canceling microphone, JIS7/IPX7 rated Submersible, Tri-Watch, Memory Channels, Memory Scan and BURP.
6 Watt VHF – This radio provides the ability to customize your conversations when there are days you spend on the water further from shore. Select between 1, 3 and 6 watts for short- and long-range communication.
Backlit plus Floats – This radio is backlit and has an easy-to-read orange display for higher visibility in all conditions. The orange core floating design also makes it easier to retrieve your radio if dropped overboard.
USA, Canada & International Channels – Maximum coverage wherever you go. This VHF marine radio allows operation on any of the three different channel maps established for these areas.
NOAA Weather & Emergency Radio – Be prepared and never surprised when it comes to changes on the water. Get 24-hour updates on threatening weather conditions, emergencies, and incoming hazards with built-in NOAA Weather radio channel.
