Price: $59.95 - $34.98
(as of Apr 08, 2025 13:15:27 UTC – Details)
[sc name="tester"][/sc]
Compact design with up to 23-mile range. With weather alerts be prepared for storms and emergencies with built-in NOAA radio receiver. Voice-activated (VOX) transmission frees hands for other tasks. Five selectable tones will distinguish between different parties for incoming calls. A total of 2662 channel combinations are available when the 22 channels are combined with the 121 privacy codes (38 CTCSS/83 DCS). These combinations prevent interference from other radios.
22 CHANNELS AND 121 PRIVACY CODES – These easy-to-use walkie talkies combine 22 channels and 121 privacy codes to secure your conversations from surrounding hikers, hunters or wherever your adventure takes you.
NOAA WEATHER CHANNELS – Get 24/7 access to NOAA weather channels so you can always be prepared and connected with those you are traveling with in the instance you run into bad weather conditions.
VOICE-ACTIVATED TRANSMISSION (VOX) – Hands-free usage to automatically transmit when you speak so you can keep your arms and hands free. Great when hunting or for construction sites or other working conditions.
CALL TONES – 5 selectable tones to distinguish between different parties as well as a channel scan feature so you can automatically scan channels for incoming transmissions. Communicate clear in working areas like hotel, security, and construction.
