CJOIAW Electric Lunch Box Food Heater, Portable Heated Lunch Box 1.8L High capacity 304 Stainless Steel Container food grade liner for Car Truck Work Adults Food Heating, 110V/12V/24V 70W.
Price: $43.99 - $39.99
(as of Mar 15, 2025 16:15:19 UTC – Details)
【70W Fast heating】CJOIAW electric heating lunch box uses an upgraded 70W power supply for heating, constant temperature heating, low-consumption heat cycle ,once plugged in, the heating lunch box will heat up in 25-35 min. It not only heats your meals quickly, but is also easy to clean.
【Food Grade Mateial】CJOIAW electric lunch box is made of food-grade PP plastic and 304 stainless steel, which is high-temperature resistant, non-toxic, durable, eco-friendly and safe to use.With comfortable handle,which is portable. With our electric food warmer, you can heat your meal in office, or during travel.
【Large capacity without leaking soup】1.8L large capacity ,Don’t worry about the small capacity, it is equipped with a removable partition, which is convenient for food classification ,this electric lunch box’s lid latches and the rubber sealing ring make it totally leak-proof, keeps meals and snacks fresh, you no longer have to worry about leakage of soup.
【Superior Complete Bundle】 1x heating lunch box 1x insulated Lunch Bag, 1x stainless steel spoon & fork, 1xfood grade plastic separator 1x home-use charging cable 110V, 1x car/trucks-use charging cable 12V/ 24V 1x manual If you want to give gifts to your lover, parents, or friends, this beautiful and practical CJOIAW heating lunch box is your best choice.
