CHGeek Wireless Car Charger, 15W Fast Charging Auto Clamping Car Charger Phone Mount Phone Holder fit for iPhone 14 13 12 11 Pro Max Xs, Samsung Galaxy S23 Ultra S22 S21 S20, S10+ S9+ Note 9, etc
Price: $25.99
(as of Feb 28, 2025 21:45:17 UTC – Details)
wireless car charger iphone 14 pro maxwireless car charger iphone 14 pro max
wireless car charger mountwireless car charger mount
logologo About CHGeek
Focusing on in-vehicle electronic products, CHGeek contributes to fulfill the needs of majority of automotive users. CHGeek provides drivers with the highest quality products and services through the pursuit of technology and strict quality control. Every customer’s satisfaction is our greatest pursuits.
CHGeek 2 in 1 Design 15W Fast Charging Wireless Car Charger Auto Clamping Car Mount Windshield Dashboard Air Vent Phone Holder
A must-have for Vehicle!
Device Supports 15W Fast Wireless Charging:
-LG V50, V30…
Device Supports 10W Fast Wireless Charging:
-Samsung Galaxy S22, S22+, S21, S21+ S20, S20 Ultra, S20 Plus, S10, S10 Plus, Note 10, 10 Plus, S10E, S9, S9 Plus, …
Device Supports 7.5W Fast Wireless Charging:
-iPhone 14 / 14 Pro / 14 Pro Max / 13 / 13 Mini /13 Pro / 13 Pro Max / 12 / 12 Pro / 12 Pro Max / 11 / 11 Pro / 11 Pro Max / X/ XS / 8…
Device Supports 5W Standard Wireless Charging:
-Google Pixel 3 / 3XL…
-All enabled Device
***For 15W / 10W / 7.5W fast charging mode, QC 3.0 car charger adapter(NOT INCLUDED) is required as its power source.
Features
wireless car charger iphone 13wireless car charger iphone 13
car phone holdercar phone holder
wireless car charger iphone 12 pro maxwireless car charger iphone 12 pro max
phone holder car chargerphone holder car charger
Wide Compatibility with Aluminium Alloy Frame
The arms extend from 5.8cm/2.28in to 9.4cm/3.7in, meaning that it works with any wireless-charging-enabled phone. As long as the thickness of the phone case is less than 6mm, you can charge with it on.
Made of aluminium alloy, Frame of the wireless car phone charger is more durable and elegant.
Informative Indicator
Flashing Red -foreign obstruction detection
Solid Red – Connected to power
Solid Blue – Charging for the device
Strong Suction Cup with Reusable Gel
The viscous suction cup + switch uses the pressure principle to exhaust the internal air through pressure, which greatly increases the absorption force and firmly adheres to the the car window, etc.
You can mount the charger on an air vent making phone calls and GPS navigation more convenient than ever.
iphone wireless car chargeriphone wireless car charger
iphone 13 wireless car chargeriphone 13 wireless car charger
wireless car charger iphone 12 prowireless car charger iphone 12 pro
Unable to charge/ Slow charge / Charging intermittently:
Make sure that the phone supports the wireless charging functionCheck the power of the charging head: The minimum standard for charging head when using wireless charging is 5V 2.4A. If it is lower, the charging will be intermittent. If you have android phone, it would be better to use QC3.0 adapter.Check if the Phone Case is compatible with wireless charging: Please remove thick, uneven or rugged case,metal ring holder, metal attachments and credit cards for optimal charging. Be sure your phone case is NOT thicker than 6mm.Preventing your phone from overheating: We suggest you close Apps to reduce power consumtion and turn off phone screen during wireless charging.
The suction cup won’t stay or be attached to the dash:
How to ensure strong adsorption of the suction cup? The bottom is washable suction cup and pad. Rinsing and air drying the suction cup and pad after using for a long time can restore their stickiness. We do not recommend to apply the suction cup on leather, wall or filmed glass surfaces as the suction cup is designed with strong viscosity and attraction.How to ensure the stability: We suggest you use the STICKY GEL PAD in irregular surface of the dashboard , and then press the suction cup on the pad to ensure the STABILITY. Before placing the product on the dashboard, you need to turn the button on, then press the product where you want it to be, and finally buckle the button.NOTE: The bottom suction cup maybe harden when it is cold. this may affect the sticky function of the sucker, so we suggest you warming up the sucker pad from hot air blowing on it from the vent firstly, then stick it on the dashboard or other surfaceAbout the air vent: Only support horizontal and vertical air vent, not support the round air vent.
Clamping Arms won’t work:
If the arm clamp is obstructed, it will stop working and wait for the next action to close. If it is this case, please clear the obstacle and press the induction button to reset the product into the closed state, and use the switch again to use it normally.If the product is out of power, the arm clamp will not work. Please plug the cable into the QC3.0 car charger to ensure that the motor have enough electricity when you clamp or release the phone, otherwise the clamping arms will not move.Battery damage.
【INTELLIGENT IDENTIFICATION & SMART CHARGING】When connecting to the cable, the phone car mount will automatically clamp when phone is dropped in, make your driving easier and safer. A gentle touch on the 2 sides button of the charger can make the arms open. When your phone is fully charged, the wireless car phone charger will automatically power off and protect the battery of your phone
【FOREIGN OBJECT DETECTION with LED ALARM】When there is a metal substance between the wireless car charger mount and the phone, the car wireless charger will stop charging and the red light flashes to alarm. Effectively avoid the damage of the mobile phone caused by the high temperature of the metal Bullet Point
【CASE FRIENDLY & FLEXIBLE ANGLE ADJUSTMENT】CHGeek phone holder for car supports charging through phones cases up to 6mm thick. Please note that cases made of metal, external attachments such as magnets, credit cards, grips, and stands will interfere with charging. The 360°rotating sphere and the retractable & foldable bracket allows for optimum viewing and safe driving
【2-IN-1 Design】 Combines the Wireless Charger and a car cell phone holder, allows for a secure hands-free experience. Keep you away from the tangled locating cords or cables. Cell phone holder is suitable for car Windshield Dashboard Air Vent installation, and makes GPS and phone call more convenient
