Cell Phone Booster for Home,Cell Phone Signal Repeater Boosts 5G 4G LTE for Verizon AT&T T-Mobile All U.S. Carriers,Work on Band 2/4/5/12/17/13/25/66, FCC Approved Up to 5000sq ft
Price: $119.00
(as of Apr 18, 2025 00:30:26 UTC – Details)
5G Compatible:Cell phone booster support 5G and deliver amazing speeds; Only 5G that carriers have deployed in large numbers in existing 4G brands through DSS (Dynamic Spectrum Sharing), the FCC has not yet allowed the new mmWave band and T-Mobile 600MHz cellular enhancers, so if you must use 5G, Make sure your area has 5G services in the existing 4G band before you purchase.
Eay Installation Keep the power is off during installing/adjusting antennas. Simply set up the outdoor Log-periodic antenna, and place signal booster where you want. Make sure the distance between the outdoor antenna and indoor antenna should be about 32ft. Following the user manual, you can easily set it up.
FCC & IC Certified: :Cell booster complies with all FCC and IC guidelines and meet the requirements of application standards,does not interrupt or compromise any carrier’s signal to and from the cell tower.
3 YEARS WARRANTY : cell phone signal booster 3 YEARS MANUFACTURER WARRANTY. If you have any installation or other problems with your item, please contact with us anytime.
