CCYLEZ 3G 4G LTE USB WiFi Router, Vehicle Router via Standard USB Port, 150Mbps Portable Router for Tablets, Laptops, Cell Phones and Different Types of WiFi Devices
Price: $18.40
(as of Mar 20, 2025 13:45:14 UTC – Details)
Spec:
Item Type: 4G LTE USB WiFi Router
Material: ABS
Color: Black
USB: Standard USB Interface
Card Slot: Standard SIM Card Slot (without SIM Card)
Transmission 4G Speed: 150Mbps Downlink
4G LTE FDD: B1/B3/B5
3G WCDMA UMTS: B1
WiFi: Support IEEE802.11b/g/n Band 2.4G
How to Use:
Just take out the product to use
PackageList:
1 x Router
1 x User Manual
Note:
1.Without SIM Card2.You need to disable the PIN codes of SIM card and modify the APN. please make sure the SIM card is activated, roaming service and virtual SIM card, IOT SIM card are not supported; in rural areas, the uncovered signal will be disconnected for a period of time, which is a normal sign.
3.Before purchasing, check the frequency band used by your local carrier to ensure that it is compatible with your local usage.
4G NETWORK: WiFi modem supports both 3G and 4G networks, using a standard SIM card as long as you have a 3G 4G SIM card, you can connect to a 3G 4G network.
SCOPE OF APPLICATION: 4G router is made of ABS material, durable and suitable for tablets, laptops, cell phones and different types of WIFI devices that can connect to 4G WiFi router to access the Internet.
SUPPORT 10 USERS: 4G router supports up to 10 users to access WiFi network at the same time, USB power, easy to use, lightweight and portable.
150MBPS: Mobile Wifi router with up to 150Mbps wireless connection speed, you will enjoy a powerful internet experience for surfing, chatting and entertainment.
