Price: $24.99 - $20.99
(as of Apr 25, 2025 06:45:22 UTC – Details)
Carsolt Electric Lunch Box Food Heater – 3 in 1 Portable Leakproof Heated Lunch Box for Car/Home/Adults with 1.5L Removable 304 Stainless Steel Container Fork Spoon, 12V/24V/110V (Light Purple)
【PTC Heating Technology & Faster】It adopts constant temperature PTC heating, which has dual functions of rapid heating and food insulation. low-consumption heat cycle, it can be heated to the best temperature within 30-50 minutes, and automatically turn on the heat preservation mode to maintain the fresh taste of the food. (Note: If the food was taken out of the fridge, the heating time should be extended appropriately).
【Upgrade Leakproof Sealing Ring】In order to have better sealing, we have made an upgraded process, and the lid lock and rubber sealing ring of the lunch box makes it completely leak-proof, and easily use in car sloshing environments! The lunch box is equipped with a thermal insulation bag made of aluminum foil and an anti-scalding handle design, which is very convenient to carry!
【3 in 1 Portable Food Warmer】This heating lunch box is equipped with 2 power adapters: a 110V home indoor adapter, a 12V/24V car, and a truck adapter. Plugin the power to heat up the food, it can be used at home/office/car/truck. Let you enjoy fresh and hot meals whether you are working outdoors or indoors! This is also an ideal warm gift for family and friends! (THIS ITEM IS NOT INTENDED FOR USE BY CHILDREN 12 AND UNDER.)
【Removable & Easy to Clean】The electric heating lunch box contains a 1.5L large-capacity stainless steel inner tray and a 0.45L plastic box, which can be used to separate different kinds of food to meet diversified dining needs. Both are detachable, so you can take them out and clean them, or put them in the dishwasher. (Note: Please do not wash the external lunch box directly with water, and do not add water to the heating base.)
