Price: $14.99
(as of Apr 18, 2025 23:15:20 UTC – Details)
★The jet lighter made of polished zinc alloy metal and manufactured, durable, long-lasting. This lighters is handy and safe especially for for candle, BBQ, camping, fireplace, stove etc. The lighter is a great gifts idea for Friend, Husband, Father’s Day, Birthday, Christmas etc
★This light weight windproof lighter easy to carry, just put in your pocket.The jet butane lighters has anti-slip design
★Gas lighter has a window so you can see how much fuel you have left. The lighter has a gas capacity of 0.86 g and fully filled butane gas can use for 10-20mins
FLAME CONTROL:
★Light as a lighter but better,please use the hand spinning lighter at the bottom of the regulating wheel,the flame height adjustment;Increase the flame height,should follow the “+” direction.
★Reducing the height of the flames should follow the “-“direction,but each time the rotation Angle is less than 1/6 circle,otherwise it will led to cann’t catch fire.
★The optimum height of 1.0-1.5 cm flame,Flame height range:min:20mm,max55(at room) temperature of 22℃.
TECHNICAL PARMERTER:
★Measurement: 20.5*23*190mm
★Gorss weight: 106g
★Pressure inside: (0.35+0.05)MAP
★Burning time: 10-20mins
★Flame temperature: 1300℃
★Gas-tank capacity:0.86g
WARNING:
★Flame is invisible in the sun,it become harmful when careless used.
★The top turns scalding hot in use .Do not touch or push.
★Ensure that the flame is out when put down the pencil torch
★Keep away from flammable material
★Do not place or refill the torch near flame,heater,or flammable material.
★Do not place it in sun or place where temperature is over 40
★Keep away from children
★In order to keeping a strong flame and prevent clogging of port, please use high-quality butane for filling.
★【Professional Design】:This light weight windproof lighter easy to carry, just put in your pocket.The jet butane lighters has anti-slip design
★【Level Window & Large Gas Can】 : Gas lighter has a window so you can see how much fuel you have left. The lighter has a gas capacity of 0.86 g and fully filled butane gas can use for 10-20mins
★【Good Food Assistant】:This fire lighter has powerful fire, fast ignition,resist strong winds, use in different environments,safe and hygienic,non-toxic and tasteless,convenient and fast,hotel commercial safe food at home
★【Flame Lock】: Jet gas lighter has flame lock,location ring turn left,get continuing flame.These grill lighters also feature a adjust the flame level via fuel adjustment valve that alters the size of your flame so you can tailor it to specific tasks
