Price: $9.97
(as of Mar 05, 2025 07:00:36 UTC – Details)
♥Handle length: 13cm
♥Neck Length: 11.5cm
♥Candle lighter,USB rechargeable lighter,BBQ lighter
♥7s Auto Power Off mode
♥This electric lighter adopted Dual safety switch for increased children safety.
♥With overload protection, discharge protection, short circuit protection, and overheating protection.
♥This electric lighter will make your one of the best companions for BBQ, Candle ,Stove ,Celebration Party and Camping.
How to Use:
Charge the lighter with the USB cable. The lighter is activated when you flip the safety switch and press and hold down the on button. Once released, the arc shuts off. 7s auto power-off protect you and your lighter.
♥Note:If the ignition seems weak or stops working, try to recharge the lighter.When 5 LED light up, it’s full charged.
Safety Design for Children even for arthritic hands. On/Off button gets your children away from using them. The lighter has a long elastic neck ( about 3.7 inches) to keep you safe from the flame.
Attractive Design. Electric Arc lighters are Wind & Splash Proof ,more convenient and portable than disposable lighter,never needs fuel,perfect for Candles, Camping, BBQ ,Cooking, Birthday Celebration,, hiking and traveling
USB rechargeable. Instead of using butane, it uses electricity to create plasma arcs that ignite whatever you touch them to. So instead of refueling your lighter or throwing it away and buying a new one, you just connect the USB cable to a computer or a wall outlet and recharge it.
Durable & Portable. Built-in internal 200mAh Lithium-ion battery , up to 300 spark uses can be obtained from one charge . This arc lighter is lightweight design for daily indoor and outdoor activities.
