Price: $6.99
(as of Sep 01, 2024 10:15:13 UTC – Details)
LIOPPED Lighter—–Always believe good things will happen
Have you burned yourself accidentally by ordinary lighters ignite fireworks ?
Do you find it is difficult to ignite in bad weather or when you are outside?
Are you worried that your child may light the candle without continuous supervision?
Don’t worry, all your problems will be solved by us now. Here are the 3 reasons for you to choose us
– Our lighters have a long flexible soft head that allows you to maintain a safe distance from the flame.
– USB arc lighter, the arc drives the flame, no open flame, will not be blown out.
– A safe 3-step switch button, no threat to children.
Tips
1. Be sure to press the safety button and push up the switch to start the lighter. For better using experience, please push up the switch gently then enjoy it.
2. This product will last for seven seconds after ignition, and will automatically turn off after seven seconds.
3. If you find the light is flashing, that means you need to charge it.
Specifications
Color: Black +Silver
Material: Darual Zinc-alloy + ABS
Weight: 83g *2
Size: 10.7 x 0.7 x 0.3 inches
Package Dimensions : 12.87 x 3.66 x 0.98 inches; 2.93 Ounces
Date First Available : July 27, 2021
Manufacturer : LIOPEED
ASIN : B095KJCM9J
【360° Flexible Neck & Hook】The candle lighter adopts flameless plasma technology, suitable for use in strong wind and wet environments. It has a long flexible neck , which can easily rotate 360 degrees for different lighting needs.Long lighter has hook which can be easily placed in a safe place away from kids. It’s the perfect companion for candles
【LED Battery Display】 4 battery indicators can display real time battery volume, when charging,the indicators will flash in sequence, when 4 LED lights on the barrel turn on, it is full charged
【Wind & Splash Proof】The Arc lighter adopt taser flameless plasma technology to protect the electric pulse from being blown out by strong wind or wet weather. It’s the best choose for indoor and outdoor activities. It might make a bzzzz sound after switched on, that is is the sound of an arc breaking through the air. It is absolutely normal circuit operation, NO effect on regular use
【Widely Used & 365 day guarantee】The top part of the fireplace lighter wouldn’t get damaged by candle fire, you can just clean it. This bbq lighter is the best gift for family and friends. Perfect for travel camping, hiking, BBQ grill, candle jars, incense cone, gas stove, fireworks, fireplace, kitchen cooking, if you aren’t love your lighter or any questions,please free to contact us,we are ready to help,we will provide a perfect solution
