Price: $35.99
(as of Mar 03, 2025 13:15:19 UTC – Details)
The easiest way to use the Solar Observer is to put it in the sun with the solar panel up. After charging for 8 hours in full sun, the Observer can play for about 4-6 hours depending on volume. Please keep in mind the melting point of the plastic is about 194° F. It should not be charged in a hot car or any other unusually hot places. The plastic can melt under these circumstances. No sun? No problem. Crank the handle moderately for about 90 seconds to get approximately 12 minutes of radio play, or purchase the AC adapter to charge the battery pack. If you purchased the AC adapter it is best to cycle the battery by plugging the radio in, charging the battery overnight and then unplugging it. It is also a good idea to “cycle” the battery pack every 4 to 6 months if you are going to store the radio and use it only for emergencies. This keeps the rechargeable batteries conditioned to take a charge once you are ready to use the radio.
Don’t want to crank the radio? You can insert 3-AA alkaline batteries for power.
Listen to the Observer through its built-in 2-inch speaker or headphone jack for private stereo listening. The radio is tuned by a simple needle and dial, and the display is easy to read. The display light can be turned on or off or to flashlight by the same switch.
Charges iPhone® and other phones with included standard USB port adapter and a full Observer battery or by cranking. This will allow for up to 40 minutes of talk time.
Weight: 1 lb. Size: 7.25″ W x 5.5″ H x 2″ D
4-way powered portable emergency radio with wind up hand crank generator, solar panel, 5V AC/DC with a wall adapter (not included), built-in NiMH replaceable and rechargeable battery pack or optional 3 AA batteries (not included).
Well made. Low profile carry handle for portability. Includes a built-in LED flashlight for power outages, storms, fires, and other natural disasters.
Works as an emergency mobile battery charger in a pinch with included USB port adapter for charging mobile devices, such as smart phones.
Comes with 1 Year Limited Warranty and C. Crane US based tech support.
