BXST Power Generator Portable Power Station Generator 222 Wh (60,000 mAh / 3.7 V) Solar Power Generator for Outdoors, On the Go, Travel & Camping Outdoor Emergency, Home use
Price: $149.99
(as of – Details)
Wattage :
200 watts
Large-capacity lithium battery: The solar generator has a built-in 60,000 mAh (222 Wh) high-capacity lithium battery, with an AC rated power of 200 W and a peak power of 320 W, which can be used by multiple devices at the same time.
Multifunctional Solar Power Supply: The charging station has a smart LCD display, you can clearly see the remaining power, input/output power. You can choose solar power or mains charging, and the output provides 3 different modes to meet the needs of different products.
Lightweight and portable: a battery power station that fits in your hand. The portable power station is equipped with LED lights to provide you with emergency lighting at ordinary times. If you need help, press the LED switch twice to turn it into an SOS light. Suitable for outdoor use, travel or camping. generators for home use.
Multiple safety protections: This solar outdoor generators multi-interface energy storage device has protections such as over-short circuit, overload, over-temperature, and under-voltage. It will stop working when it encounters overload during use, protecting your equipment.
