Price: $85.98
(as of ā Details)
BUTOA-X Upgrade Dual Backup Camera with 7'' HD1080P Monitor kit,IP69 Waterproof Night Vision Front/Rear View Reversing Camera for Truck Box Truck Trailer Semi-Trailer RV Pickup Truck Easy InstallationFast and Super Easy to Install ā Weāve made this rear view camera systems a breeze for simple DIY installation. Power with car charger or hardwire for 9-36 volts. This is simple plug-and-play with no experience needed. The camera is connected to the carlights. Reverse camera with 49.2ft long 4-pin aviation interface extension cables, the connection is more firm, simple and durable, signal transmission is more stronger and stable.
100% Waterproof and Super Night Vision ā BUTOA-X Industry standard IP69 waterproofing fully protects your rv camera system in all kinds of weather. and with hard metal housing, high and low temperature resistance. Stay safe at night with vivid Night Vision images in low light. Lets you clearly see objects up to 50 feet behind you using the latest 18 LED Infrared.
Easy to Use Setting ā BUTOA-X Comes with its own IR Remote Controller that supports rotate mirror/flip function. Backup guide lines optional to turns on/off, moved up and down, widened and narrowed. You can also adjust brightness, contrast, and color. This system is easy and intuitive to use with 2 simple ways to install either Standing or Mounted.
100% After Sales Warranty ā Thanks for your purchase comes with 3-years warranty to fully ensure your satisfaction. Please contact us immediately if you experience a problem. We quickly replace damaged parts to make sure your system works normally. BUTOA-X is always there for you.
