BougeRV 1100Wh Solar Generator with Solar Panel 130W, Portable Power Station with 3x110V/1200W AC Outlet, Generator for Home Use Outdoor Camping Travel Emergency Backup
Price: $249.00
(as of Mar 03, 2025 17:45:17 UTC – Details)
【 Great Solar Energy Conversion Efficiency 】Adopted 9BB mono solar cell,solar panels boost a 23% recharging efficiency with its MPPT solar regulator,which better captures light and collects current.Besides,the portable panel has a built-in kickstand to help better position.
【 Power Multiple Home Appliances——10 Outputs 】Our camping power station owns 3*110V Pure Sine Wave AC Outlets,1*USB PD 60W (Input/Output Supported),1*USB QC3.0 ports,2*USB-A ports,2*DC ports,1*12V car charging port,great for AC household appliances or large electrical devices on trips,camping or work sites,such as full-size refrigerator,CPAP machine,TV,heater,electric grill,electric blanket,smartphone,laptop,etc.
【 Quiet, Safe & Stand To Last 】 Shell of the portable power station is constructed of aluminum material,greatly protecting outdoor generators against being dropped or bumped.After bumpy short road trips,the outdoor generator is still intact.In addition,this design also greatly speeds up heat dissipation with a low noise effect.
【 Portable, Simple & Easy To Use 】Foldable and lightweight solar panel is easy to store or set up anywhere,quickly transferring place.Then,the portable power generator also own intuitive screen displays,letting you know the situation of the power station better.Apart from this,detailed instructions and a one-way connection between panels and the power station can liberate your brain better,very easy to use!
【 Treat Yourself The Same——Indoor Or Outdoor】Solor generator kit can be used as home emergency backup power while energy blackout.Say goodbye to panic for power outages.Besides,even outdoors,you can enjoy a high quality of life,just like making your own coffee at home in the morning.Feel at home when outdoors.A great companion for outdoor adventures.
【 What You Get 】: 1x BougeRV 1100Wh Power Station, 1x BougeRV 130W Solar Panel, 1x AC Charger, 1x Solar Charging Cable, 1x Car Charging Cable, 2x User Manuals
