Bolton Technical Blazer Max | 4G LTE CAT6 WiFi 6 Portable Cellular Router | Up to 1.2 Gbps speeds for Verizon, T-Mobile, AT&T
Price: $369.99
(as of Jan 08, 2025 11:45:26 UTC – Details)
📶 Works with Any Major Carriers SIM Cards: The Blazer Max router is compatible with SIM cards from all major carriers, including Verizon, AT&T, and T-Mobile. Stay connected wherever you are, with the freedom to choose your preferred network provider.
📶 Deploy Anywhere with Vandal-Resistant Design: Designed to withstand tough conditions, the Blazer Max cellular router is both rugged and portable. It fits seamlessly into any home or office setup, and once the initial setup is complete, it can be deployed anywhere you need it – from vehicles and factories to homes and IoT applications.
📶 Incredible Security, On and Offline: Rest easy knowing that the Bolton Blazer Max mobile router provides exceptional security. It can be configured to support a wide range of network security protocols, including VPN, WPA3 Protocol, DNS over HTTPS/TLS, CloudFlare, IPv6, and more, ensuring your data is safe and secure.
📶 Quad-Port Action for Fast Network Speeds: With four 1 Gbps configurable LAN/WAN ports, the Blazer Max router brings fast network speeds right where you need them. Stay connected with the convenience of an always-online connection, and enjoy a constant connection with the automatic reboot feature. FCC/IC, PTCRB, and GCF approved for reliable performance.
