BODEGA 【Upgraded】 12 Volt Car Refrigerator, Portable Freezer, Car Fridge Dual Zone WIFI APP Control, 80 Quart(75L -4℉-68℉Car Cooler, 12/24V DC and 100-240V AC, for Travel, Camping, Outdoor and RV
Price: $227.99
(as of Jan 16, 2025 07:15:24 UTC – Details)
BODEGA Professional 12V Car Refrigerator, it is a good companion and car fridge in your life
car fridgecar fridge
BODEGA Portable Car Refrigerator Brings happy for your Travel
A car trip is exactly needed after a long period of lock down. It could be the perfect relaxing entertainment when hardwork, housework, farm work or babysitting etc., finished. You might plan to strike out on a camping trip, enjoy the beach, or maybe have a picnic in the park. However, trips could be so boring without food and drink. Which means a cooler to keep your food fresh and beverages chilled is what you need.
This is where our story started. BODEGA focus on designs and manufactures car fridges for RVers, van owners, overlanders, truck owners and the outdoor communities to keep their food fresh and beverage cold on the road.
BODEGA car firdge advantages:
Convenience of APP controlDual Zone independent controlLarge capacity 80 Quart(75L)-4℉(-20℃)-68℉(20℃)Temperature SettingWheel,Retractable handle,Door Removable and Inside Led Friendly DesignVoltage protection H/M/L,Max/Eco Cooling ChoiceCan be use at home or Car,Support 12/24V DC and 100-240V AC.
CAR FRIDGECAR FRIDGE BODEGA car refrigerator is equipped with a bottle opener
Packaging includes
Portable Refrigerator * 1Cigarette Lighter Connector * 1Wall Plug * 1Wall Plug Adapter * 1Dual Zone Basket*1User Manual *1 Please note: if you find any damage after receiving the car refrigerator, please find us in time, and we will provide you with free replacement parts. The applicable environment of the car refrigerator: -10°C~43°C (14°F~110°F).
Convenient APP control
Compare with normal Manual Car Fridge,
Our BODEGA Fridge can support APP control.
You would be convenient to follow the development of the refrigerator all the time when driving
Please noted below point:
If you need to store food (What is Sensitive to temperature) when traveling, we recommend that you pre-cool the fridge before you go to travel. Kindly remind: Please authorize the wireless connection function and authorization positioning after you complete the App installation and open GPS. Please tell us if you have any difficulties. Kindly reminder: The car refrigerator can only connect 1 mobile phone, do not support the connection of two or more mobile phones. Kindly reminder: Please take waterproof/rainproof measures to prevent water droplets from leaking into the display and causing the control panel to corrode. kindly reminder: Do not expose your fridge to heat and direct sunlight.
Bearing WeightBearing Weight
22
Support 12/24V DC and 100-240VSupport 12/24V DC and 100-240V
Bearing Weight
With BODEGA 35L car refrigerator large capacity, the room is big enough to keep food fresh and drinks cold on the journey.
Anti-shaking for extreme off-road conditions
With good compressor technology, this portable freezer can still work great even when you spend a lot of time off roading on bumpy roads with steep inclines and declines.
Door removable or switch direction
The door of the car refrigerator can be easily disassembled and can freely switch directions, which is very convenient for your daily life. You can install the door of the car refrigerator from the left or right according to your preferences.
Support 12/24V DC or 100~240VAC And Support installation of additional accessories.
Accessories can be installed in this place but are not included and need to be purchased.
With 2 power cables, widely used in both indoor and outdoor occasions, boat, truck, car and so on.
33
Removable BasketRemovable Basket
LED lightLED light
BODEGA 12 Volt RefrigeratorBODEGA 12 Volt Refrigerator
Dual Zone (Freezer and Fridge)settings
With BODEGA 75L car refrigerator large capacity, the room is big enough to keep food fresh and drinks cold on the journey.
Removable Basket
The two-piece impermeable internal basket convenient for you to store food and keep them in perfect condition on your journey. It also can be easily taken out when you need it.
Built-in LED lights
BODEGA car refrigerator equipped with built-in LED lights which allows us to clearly see the food and drinks inside whether it is day or night.Also make it easy for you to find the food you want.
Cleaning Hole
BODEGA car refrigerator has a unique cleaning hole design.The bottom drain hole drains the water out quickly, which is convenient for cleaning the car fridge.
HOW CAN I RUN BODEGA PORTABLE FREEZER?
1) You can run this portable freezer fridge with 12/24 V DC power on various vehicles, such as SUV, Truck, RV, Camper, Van, Boat, etc.
2) BODEGA car refrigerator running with Solar panel Power station ( 240W / 500W/ 1000W )
3) BODEGA car fridge also working on 110~220V Home outlet,wall socket.
Note: Products with electrical plugs are designed for use in the US. Outlets and voltage differ internationally and this product may require an adapter or converter for use in your destination. Please check compatibility before purchasing.
11
Low Voltage Protection
Level H/M/L,Each level with different start voltage and auto stop voltage.
11
Battery Protection Detail
Through DC power output, Plug into the refrigerator power, adjust the voltage, and record the voltage of start and stop working of the refrigerator
11
Cooling time Test (Max)
Normal Temperature at room, Max and -20℃ setting
11
Cooling time Test (Eco)
Normal Temperature at room, ECO and -20℃ setting
11
11
11
11
Item Weight
23 pounds 37.5 pounds 27.2pounds 1.6 Cubic Feet 51.8 pounds 25.6pounds
Item size
21.18×7.48×15.35 inches 28.50×14.10×21.60 inches 24x13x14 inch 14.96 x 18.86 x 21.1 inch 35.04×17.13×15.94 inches 24*13*12 inch
Capacity
16 Quart 64 Quart 27 Quart 45L(1.6cu.ft) 45 Quart 20 Quart
Left Zone
36 Quart 22.5 Quart
Right Zone
28 Quart 22.5 Quart
Temperature Setting
5℉-68℉ -4℉-68℉ -4℉-68℉ -4℉-46℉ -4℉-68℉ -4℉-46℉
Support App control
Can remove the middle plate
No Yes No No No No
15 min to 32℉
Battery Protection
👍🥂APP CONTROL & VOLTAGE PROTECTION:Upgraded WiFi connection car refrigerator. BODEGA car fridge with APP control, you can control the freezer from distance or in car.Intelligent temperature control function to meet the required temperature of various ingredients. H/M/L 3-level low-voltage protection:When the measured DC voltage falls below the cut-off value, the compressor will off to prevent the vehicle from running out of power
👍🥂EXTENSIBLE HANDLE & REMOVABLE DOORS:The detachable handle design of the portable fridge makes the car refrigerator easier to move and portable. The car refrigerator door is detachable and can be installed according to your applicable direction for flexible application.12v fridge equipped with a multi-functional non-slip base, the lateral displacement is greatly reduced. When your car is climbing at an inclination angle of 30 degrees, the car portable freezer can still run stably
👍🥂VALUE PACK AND FRIENDLY DESIGN: You will get portable refrigerator * 1, cigarette lighter connector * 1, wall plug * 1, wall plug adapter * 1, user manual * 1, dual zone basket*1, USB socket*1, bottle opener*1. And our refrigerator have wheels, retractable handle, inside led light, USB socket, bottle opener it is very convenient for your daily use. BODEGA car refrigerator compatible with various power sources to meet your life needs
👍🥂 WARRANTY&SUPPORT: 5 Years Life Span on the compressor and 1 Year warranty on all other parts.We have a professional technical support team responsible for the portable car freezer.If you have any problems,please feel free to contact us via Amazon.We will response you in 24 hours and let you have an wonderful experience.BODEGA car fridge 12v is equipped with 120/240V AC and 12/24V DC adapters, which can be used at home or in the car.The RV freezer line length is about 2.6m.
