BMK 200W Car Power Inverter/Plug Adapter Outlet Charger DC 12V to 110V Inverter with 1.2A&2.4A USB, 1 QC3.0 USB and 1 Type C Ports
Price: $27.99
(as of Feb 27, 2025 13:45:15 UTC – Details)
car inverter can be  used in car and charge for your all electronic devices.car inverter can be  used in car and charge for your all electronic devices.
one car inverter lay on the car and charge for phone and car vaccum cleanerone car inverter lay on the car and charge for phone and car vaccum cleaner
power outlet carpower outlet car Modified Pure Sine Wave
High efficiency and Greatly reduces the power loss of this system
Short-Circuit Protection Over-Heat Protection Over-Voltage Protection Over-Charge Protection Low-Voltage Protection Over-Load Protection
BMK’s Power Inverter with 4 USB ports(2.4A USB+1.2A USB+QC3.0+30W Type-C) and 2 AC outlet, only for DC 12V, and great for your Ipad, laptop,smart phone, car vacuum, car infaltable and game console. What’s more, it is normal that the inverter will become warm when you use. so please let it keep away from the place which is easy to produce heat.
Note: Do not use to power high-power electrical equipment, such as hair dryers, electric heaters, which may blow the fuse.
Specification: Type-C Output: 30W Max Current for USB Ports: 6.2A Cigarette Lighter Input Power: 200W Voltage for AC Outlet: AC110V+-10% DC Input Voltage: 12V Size:7.1*5.1*1.7 inches
BMK car inverter are powering up for phone , Ipad at the same time BMK car inverter are powering up for phone , Ipad at the same time
there is a cooling fan that is installed in the inverter there is a cooling fan that is installed in the inverter
a car cigerette lighter can can a socket too a car cigerette lighter can can a socket too
Fast Speed Charging:
Four usb ports can be used at the same time, QC3.0 port can provide you fast charging your electric devices withine one hours.
Silent Cooling Fan
The fan will help heat dissipation to protect your equipment, it also will be running faster when the device gets warmer or output power reach to over 60W .
Cigerette Lighter Socket:
you can use it to charge your electric devices and it’s also ready for your Car Diffuser, RV refrigerator, Car TV, Vacuum cleaner, Power amplifier portable Cooler/Warmers, Air compressor.
four scenes show that our car inverter can be used four scenes show that our car inverter can be used
Rated Power
200W 200W 200W 200W 200W
USB Port
2.4A USB+1.2A USB+QC3.0+Type C 2.4A USB+1.2A USB+QC3.0+Type C 5V 2.4A 2USB+QC3.0 2USB 5V 2.4A 2USB+QC3.0 2USB 5V 2.4A 2USB+Type C
Type C Port
PD30W PD30W PD18W
Cigarette Lighter Socket
Accessory
Gel Pad
【4 USB Fast Charging and Switches ON/OFF for AC Outlets】 Four usb ports can work at the same time without opening switches and the total current is 6.2A when you use simultaneous; QC ports can shorten your charging time and refill your battery in one hours; USB C working as both input and output and let you fast refuel your charger which is perfectly fit your newest iPhone, Android. Built in on/off switch to control the car adapter electric plug for safer usage.
【Smart Cooling fan and LCD screen】 Built-in smart temperature-controlled cooling fan helps reduce heat and prevent shortages, and the frequency of rotation will become faster as the temperature rises, but that is normal phenomenon. In addition, the LCD screen will show you the dc input voltage and then you can detect the status of the car outlet adapter when connected with the cigarette lighter plug and charge your electric devices.
【Superior Safety】 Built-in fuse to protect your device and comprehensive multiprotect safety system includes overcharge protection, short circuit protection,temperature control, under voltage charging,over voltage overloads protection.It helps protect your charging devices and extends the time of being used.
【Support Services 】Pouring our heart into serving for providing the best power inverter t you! We accept return & replacement and 24-hour consulting. Any problem can be solved within 12 hours and please feel free to contact us with any question.
