Price: $109.99
(as of – Details)
Bailibatt Portable Power Station 150W, 146Wh Camping Solar Generator, Lithium Battery Bank Power Supply with 2 110V/150W (Peak 300W) AC/2DC/2USB/ 1QC 3.0/1USB-C for CPAP Home Camping Emergency, Orange
π Fast Charge & Versatile Battery Outlet – BailiBatt mini generator portable has 8 Outputs : 2* AC outlet (110V/150W, 300W Peak), 1*Type-c port(PD 24W), 2* USB-A ports,1*QC 3.0, 2*12vDC ports. The portable small generators can charge phone, tablets, laptops, CP-AP and other camping devices under 150W, without bothering noise, no fuel or gasoline, very environmental and quite
π Power Your Outdoor Life – Clear LCD screen shows all portable electric generators operating status easily and timely. Light weight (3.7 lbs) and compact handle design, so the BailiBatt lithium power station is easy to charge anywhere and anytime. And this battery powered outlet also has three lighting modes (steady light, SOS, flashing mode) to meet your different needs
π Three Recharging Modes High Efficiency Solar Generator – There are three methods to recharge the battery pack with ac outlet: 1) 12-20V/2A,οΌΞ¦ 5.5*2.1mm)DC adapters, about 7hours; 2) 40W/18V solar panel (NOT INCLUDED), about 6-8hours; 3) socket of the car and car charger, about 7hours. The BailiBatt small camping generator built-in a MPPT controller, you can use with confidence
π Stable & Practical – The solar powered generator built-in an advanced BMS (Battery Management System) with the protection of over-load, over-voltage, over-current, over-heart, short-circuit, over-charge and over-discharge, which prevent your devices from damaging. And the portable laptop charger also designed with the cooling vents to help it stay in a constant temperature range
π 24 Months Warranty – You will receive 1* 146Wh portable power bank with ac outlet, 1*AC adapter, 1*user manual, 7*24 hrs prompt and friendly customer service. Any questions, please feel freely to contact us. For a better battery maintenance, please recharge it at least once every 1-2 months if it’s not in use
π TIPS: Please press the “AC” button for THREE seconds to turn on/off the AC output
