AUTO-VOX CS-2 Wireless Backup Camera with 4.3” Monitor System, Stable Digital Signal Waterproof Back Up Camera for Cars, Clear Night Vision Reverse Camera for Truck, SUV, Van, Trailer
Price: $99.99
(as of Apr 17, 2025 13:30:31 UTC – Details)
*Wireless specifically refers to the transmission between the camera and monitor. You will still need to wire the camera to a power supply.
towing a trailer/boattowing a trailer/boat
Why choose AUTO-VOX CS-2 backup camera?
1. Stable digital signal transmission
2. Wireless for 2 steps easy installation
3. Build-in transmitter on camera, save place and Installation
4. High compatibility for cars ( suit for cars which are under 33ft, or you can purchase extension cable B07BNG6XHZ to extend its wireless range)
Important tips for customers: anymore
1. For reversing use, please connect the backup camera to the reverse light. and the rear view image will show up automatically once enter into reverse mode.
2. For monitoring use, please connect the backup camera to the constant power, and the monitor will display the rear view image all the time, which can be used on towing a car/trailer/boat, there is no need to stop/turn back to check anymore.
3. The car charger is around 12ft, the power adapter is around 5.08ft and the wire near the camera is 4.82ft.
Backup camera for truck/car/Minivan/RVBackup camera for truck/car/Minivan/RV
In Summer, temperatures are too high in some areas, such as Phoenix, Las Vegas and Riverside, etc. Here are some tips for you to use a backup camera kit longer in summer:
1. Park your car in a cool place to escape the heat.
2. If the temperature inside the car is too high, you can turn on the air conditioner to cool down.
3. If time permits, we should first open the doors and windows to ventilate and cool down.
4. Install the monitor in a place where it can be temporarily removed when not in use and installed when needed.
5. Blocking the front glass can effectively reduce the temperature inside the car.
6. Apply a film to the window to block the heat and ultraviolet rays inside the sun.
backup camerabackup camera
Stable signal transmission
There are no distortion issues like miscolored picture that appears on other digital backup cameras. Keep away from unstable analog signal transmission.
Normal&Mirror Image
CS2 backup camera supports Normal and Mirror image. You can install the rear camera on the front of your car to avoid any blind spots.
110 degree rear camera
CS2 rearview camera catches a wide visible range with 110 degrees, which also has 0.1 low lumen to present clear image.Waterproof IP68 rear camera will be more durable. It has a double-sided adhesive come with it, you can attach it to your license plate.
Waterproof backup cameraWaterproof backup camera
Adjustable Parking Line
There are 6 parking lines, you can choose anyone according to your car. If you do not need, you can also set it on the monitor.
Durable&Waterproof Backup Camera
The camera is IP68 waterproof standard, which ensures camera can work fine in any weather, and no need to worry about the car wash.
Small Antenna
Please pay attention during installation, please set the antenna up so it can get the best signal.
washable suction cupwashable suction cup
movable bracketmovable bracket
felixable mount  positionfelixable mount  position
Washable Suction Cup
If the suction cup gets dirty, please clear it with clean water to quickly restore its stickiness. Note: Place the bracket on a flat dashboard or windshield to ensure it is fully attached.
Movable Bracket
Step1: loose the screw, and rotate the direction of bracket (not the camera) to make it right Step2: Screw it back on.
Flexible Mount Position
You can freely mount the camera on the bottom of the license plate, which can avoid obstacles, like license plate light, door handle.
11
Camera Power Source
Reverse Lamp Solar Battery(3350) Battery(6600) Reverse Lamp
Wireless Range for Vehicle
Under 33ft Under 40ft Under 23ft Under 50ft Under 44ft
Image Quality
480P 480P 720P 1080P 480P
Monitor Size
4.3″ 5″ 5″ 7″ 5″
Working Time
Always On 45s/60s/90s/120s 45s/60s/90s 120s/240s/Never Always On
View Angle
110 110 110 90 110
Support Camera Channel
1 Camera Channel 1 Camera Channel 2 Camera Channels 2 Camera Channels 1 Camera Channel
Waterproof Rating
IP68 IP69 IP68 IP69 IP68
【Vivid Image Restoration & Superior Night Vision】The wireless backup camera for car with 4.3” Monitor is designed with the PC1058 sensor, which provides vivid and smooth images. Backup camera for car with Adjustable 6-glass lens and a 0.1-lumen rating presents superior night vision. Restoring what you see behind your car directly.
【Wireless for 2 Steps Easy Installation】Compared to wired backup camera for truck,The back up camera systems for truck with no wires connecting from the monitor to the reverse camera. You only need to operate two steps to quickly install:①Power the monitor with the included cigarette lighter or Fuse box;②Connect the wireless rear view camera to continuous power for monitoring, or connect to the reverse lamp for reversing.
【 Parking Safely & Effortlessly】Wireless backup camera for truck comes with 110 golden angles to provide an accurate view of the area behind the vehicle, making it easier to park or hitch up a trailer. Together the adjustable parking lines help you efficiently fit your vehicle into even the tightest parking spots. Worry-free parallel park and reverse.
【Multi-function Vehicle Backup Camera】Back up camera for cars with IP68 waterproof standard to withstand rainy, cloudy, foggy weather, and will never fog up or cause the wireless back up camera to be blurry & white screen.t. The image can be flipped between mirror (rear view) and facing (front view). You can use the camera as rear backup camera wireless or front camera optional.
