Price: $268.83 - $159.99
(as of Mar 22, 2025 04:45:19 UTC – Details)
JENSEN JTV1917DVDC 19″ LED TV with Build-In DVD Player, High Performance Wide 16:9 LCD Panel, Resolution 1366 x 768, Integrated HDTV (ATSC) Tuner, HDTV Ready (1080p, 720p, 480p), 12V DC Power – Replaces the discontinued JE1914DVDC
The compact TV/DVD design of the JTV1917DVDC saves spaces in an RV by eliminating the need for additional electronics. By functioning on a 12V DC power system, JTV1917DVDC draws a low power consumption making it perfect for dry camping. In the off season, the included 110V AC/DC power adapter allows RVers to move their TV from the RV in to their home.
Key Features
- 12V DC Power
- Built-in DVD player
- High performance wide 16:9 LCD panel
- 1366 x 768 resolution
- 16.7 million colors
- Integrated HDTV (ASTC) tuner
- HD ready (1080p, 720p, 480p)
- VESA 75mm x 75mm mounting pattern
- Full function wireless remote control included
- 12VDC cigarette adapter cable included
- 110VAC AC/DC power adapter included
Specifications
- Diagonal Screen Size (Inches): 18.5
- Video / Display System: NTSC/ATSC/PAL
- Aspect Ratio: 16:9
- Resolution: 1366 x 768
- Brightness (cd/m2): 200 nit
- Contrast Ratio: 1000:1
- View Angles: Top 89°, Bottom 89°, Left 89°, Right 89°
- Speaker Audio Output: 3Wx2
- Power System: 12VDC
- HDTV Ready: Yes
- Composite Video Input: 1x NTSC/PAL Compatible
- Component Video Input: 1x Y, Pb, Pr
- VGA Video Input: 1x
- VGA audio input (3.5mm stereo mini phono) x 1
- HDMI (ARC) input x 1
- Selectable (variable/fixed) analog audio output (RCA) x 1
- Digital SPDIF audio output (RCA) x 1
- Headphone output x 1
- Overall Dimensions: 17.44″W x 10.97″H x 1.84″D
- Weight (Lbs): 7.0
12V DC Power, High performance wide 16:9 LCD panel, 1366 x 768 resolution, 16.7 million colors, Integrated HDTV (ASTC) tuner
HD ready (1080p, 720p, 480p), VESA 75mm x 75mm mounting pattern
12VDC cigarette adapter cable included, 110VAC AC/DC power adapter included
