Artilife 500W Small Hot Plate Mini Hot Plate,Artilife 500w Small Electric Hot Plate,Mini Stove Electric Portable Stove Kitchen Cooktop Electric Heater for Home 110V
Price: $26.99 - $18.89
(as of Mar 23, 2025 03:15:17 UTC – Details)
【Adjustable Temperature】Small hot plate level 1 to level5,and level 5 is MAX.Temperature can be controlled by dial well.
【Cycles On and Off 】Mini hot plate runs in On and Off Cycles,Cycles‘on and‘off’to maintain plate temperature.If you set level 1,it keep cutting off before the water started to boil, So if you want your water to boil quick,you need set at least level 4.
【Saves Space】Artilife mini electric stove is compact,takes up very little counter space,small enough to pack,suitable for home,hotel,office,camping,and your RV.
【Electric Camping Stove】Artilife 500W small electric hot plate is great for camping with a portable power station.
【Heats Up Fast】500w small electric hot plate preheat before use.It takes a minute or two to reach full temperature,once it has reached full temperature,it Heats-up quick.
【Solid Burner】Cast iron heating plate,Stainless steel collar,Insulated wire,Equipped with non slip rubber feet to be more stable,Solid burner surface makes it easy to clean and retains heat.
