AQTZGOS RV Wired Backup Camera System Kit, 7 Inch Backup System Mirror, RV Backup Camera, Night Vision Camera IP69K Shockproof 10G, Suitable for Tractor/Truck/RV/Bus/Excavator/Caravan/Harvester
Price: $89.99
(as of Mar 20, 2025 06:00:32 UTC – Details)
【Wired Reversing Camera, Stable Signal Transmission】: The wired reversing camera kit transmission is more stable, you will never lose the signal at any time. If your wireless backup camera is always choppy and laggy, a wired camera is a reliable companion for every drive. The extended length aviation 4-pin connector wire has strong anti-interference, tighter connection and easy installation. The special thick and hard wire can better shield the vehicle circuit interference than ordinary AV wire.
【7 Inch Screen Car Rear View Monitor】: With U-shaped metal bracket, 1024RGB x600 HD resolution. IP69 rating is completely waterproof. The power input range is DC12-32V, and supports up to 3 cameras. The built-in TVS device protects the display from being damaged by the vehicle’s instantaneous high power. This display supplies DC12V power to the camera in use, saving power. It is compatible with PAL/NTSC/AUTO.
【Clear Night Vision Camera with 18 IR Lights】: Provides ultra-clear and true color images without delay. The viewing angle is 120 degrees, and the IP69 waterproof camera with infrared light makes it possible for you to drive safely in the dark, providing you with the best night vision. With high/low temperature resistance (-4℉-198℉), waterproof IP69, 10G anti-vibration level, it can work perfectly in any vehicle with strong vibration in any extreme weather.
【Stop Line Assist】: Trigger line will automatically trigger CH2 screen with stop line. The rear view screen can be flipped through the up/down/left/right buttons, which is convenient to control mirroring or not. Stop lines will help you park more safely and quickly without having someone get out of your car to help you see the way or guide you.
【Easy Installation in 8 Minutes】: Waterproof camera and HD display. Powered by one power source, no need to power the camera and monitor separately, just connect the monitor to the cigarette lighter adapter/Acc/fuse etc, then wire the camera and monitor.
