Ambrogio.L Flexible Candle Electric Arc Lighter with LED Battery Display 10CM Long Neck,Windproof Kitchen Grill Lighter with Safety Switch USB Rechargeable Arc Lighter
Price: $8.99
(as of Mar 27, 2025 07:45:22 UTC – Details)
Features:
*Windproof arc lighter,environmentally friendly,no need of fuel
*10cm Flexible Long Neck:Keeps you a safety distance to protect you from being burned.
*Universal USB cable is included and the lighter is rechargeable through USB port, socket,etc.
*Safety Protection:Safety lock (at the bottom of lighter) must be turned on before ignition,which avoid accidental ignition effectively.
*Ambrogio.L branded and quality ensured.
About Product
■Material:Aluminum Case
■Net Weight:49g/1.72 oz
■Product Dimensions:25X1.5cm/9.84×0.59″
Attention
■Keep it away from children
■Keep out of high temperature area(Above 122℉/50℃).
■Do NOT put it into a car under sunshine
■Keep away from face and clothing during use
■Avoid prolonged exposure to direct sunlight
■Package includes 1x lighter with box and USB cable.
*Safety Protection(Safety Lock + Long Neck Design):The safety lock (at the bottom of lighter) avoids accidental ignition,much more safe to use (Note:it must be turned on before ignition). Long neck design keeps you a safety distance when using and protects you from being burned.
*USB Rechargeable and LED Remaining Power Display: The lighter is convenient to be recharged through socket,power bank,laptop etc.LED remaining power display reminds you to recharge at anytime.And Our electric lighter is equal to 300+ disposable lighters. Can be charged over 600 times. Battery capacity :up to 200mAh.
*Evironmental Friendly Lighter:Take this lighter to home and cut down on disposable plastic lighter.It generates flameless arc pulse, no oil or fluid is required, much more evironmental friendly than traditional lighters.
*Package includes 1x candle lighter(Box packed).Color: Black.Any question is welcomed to email us and we’ll strive for a satisfactory solution for you.
